Error when building rtems
Richi Dubey richidubey at gmail.com
Thu Mar 12 18:22:28 UTC 2020
Dear Dr. Bloom,
Indeed it was the version mismatch ( because I couldn't git from
rtems's repository from my university's network)
Thanks for pointing that out. Can you tell me how to change the
documentation so that the curl command also points to the latest
version ?
Regards.
Richi.
On Mon, Mar 9, 2020 at 9:38 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Mar 8, 2020 at 4:44 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Hey everyone,
> > (Sorry if this is a repost, I don't even if the earlier one went or not)
> > I am new to RTEMS development environment and I needed someone's help.
> > I downloaded rtems and the rtems source builder usnig curl command given in documentation. But now when I am running ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc inside the rtems-source-builder-4.1103/rtems, I am getting the following error:
> > RTEMS Source Builder - Set Builder, 4.11.3
> > error: exe: not found: (__makeinfo) /usr/bin/makeinfo
> > error: host build environment is not set up correctly
> > Build FAILED
> > Can someone help me out with this please?
> Niteesh makes a good point: what documentation did you use to
> determine how to build and run RTEMS?
> I see a version mismatch above. You are specifying 5/rtems-sparc from
> something downloaded that indicates version 4.11.
> > Thanks,
> > Richi.
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
