Error when building rtems
Thu Mar 12 22:24:58 UTC 2020
On Thu, Mar 12, 2020 at 4:01 PM Chris Johns <chrisj at rtems.org> wrote:
> On 13/3/20 5:22 am, Richi Dubey wrote:
> > Can you tell me how to change the
> > documentation so that the curl command also points to the latest
> > version ?
> Thank you for the offer. I have pushed changes to the User manual to update the
> Quick Start guide so it handles released source packages. The documentation
> shows 5.1.0 as this will be the version released so for now you would need to
> change the URL to the latest snapshot under
> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0.
PS: Since you are an aspiring GSoC student, you should work from the
master branch of rtems and tools. But, it is fine to get started using
the release (we do need more testing of it).
> Chris
