Error when building rtems
Richi Dubey
richidubey at gmail.com
Fri Mar 13 20:10:05 UTC 2020
Dear Dr. Bloom,
I have a the latest working master branch from git.
Thanks for suggesting!
On Fri, Mar 13, 2020 at 3:55 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 12, 2020 at 4:01 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 13/3/20 5:22 am, Richi Dubey wrote:
> > > Can you tell me how to change the
> > > documentation so that the curl command also points to the latest
> > > version ?
> > Thank you for the offer. I have pushed changes to the User manual to update the
> > Quick Start guide so it handles released source packages. The documentation
> > shows 5.1.0 as this will be the version released so for now you would need to
> > change the URL to the latest snapshot under
> > https://ftp.rtems.org/pub/rtems/releases/5/5.0.0.
> PS: Since you are an aspiring GSoC student, you should work from the
> master branch of rtems and tools. But, it is fine to get started using
> the release (we do need more testing of it).
> > Chris
