zc706 bsp does not work with maximum processors as 2
Chris Johns
chrisj at rtems.org
Thu Mar 19 22:31:10 UTC 2020
On 19/3/20 7:20 pm, Fernando Domínguez Pousa wrote:
> I compiled a version using the master branches of rtems, rtems-source-builder and rtems-libbsd from 24th of January 2020.
Thanks. Thre is something usual happening here because RTEMS contains the code
needed to start the second core ....
https://git.rtems.org/rtems/tree/bsps/arm/xilinx-zynq/start/bspsmp.c#n32
If I build for SMP and set CONFIGURE_MAXIMUM_PROCESSORS to 2 my applications run
fine. I
