zc706 bsp does not work with maximum processors as 2
Fernando Domínguez Pousa
fdpousa at gmv.com
Fri Mar 20 09:06:20 UTC 2020
> Thanks. Thre is something usual happening here because RTEMS contains the code needed to start the second core ....
I do not understand at all. So, with the current version of the repos this should work? Am I missing something in my implementation? Because I compiled RTEMS for SMP too and I configured CONFIGURE_MAXIMUM_PROCESSORS to 2.
> If I build for SMP and set CONFIGURE_MAXIMUM_PROCESSORS to 2 my applications run fine. I
Did you use a zc706 board? I remember two years ago I started two processors using SMP on a zedboard without starting second core using xsdb.
Regards,
-----Original Message-----
Sent: 19 March 2020 23:31
To: Fernando Domínguez Pousa <fdpousa at gmv.com>; Sebastian Huber <sebastian.huber at embedded-brains.de>; users at rtems.org
Subject: Re: zc706 bsp does not work with maximum processors as 2
On 19/3/20 7:20 pm, Fernando Domínguez Pousa wrote:
> I compiled a version using the master branches of rtems, rtems-source-builder and rtems-libbsd from 24th of January 2020.
https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems_tree_bsps_arm_xilinx-2Dzynq_start_bspsmp.c-23n32&d=DwIDaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=5sGCFYM3DD5oktDUUantbBuCcEkiTqjbPdBUl210BGQ&s=sXXbgnMBeFnoPLA0PJc9YlVxzTDD65jAcJKWTKBlyos&e=
P Please consider the environment before printing this e-mail.
