sptest SP06 strange behaviour
Wed Mar 25 10:01:08 UTC 2020
Hello Michele,
both tests should run without errors. Which RTEMS version do you use?
A frequent error in Cortex-M BSPs are improper interrupt priorities.
Make sure all interrupt priorities are set up correctly:
https://docs.rtems.org/branches/master/cpu-supplement/arm.html#interrupt-processing
