R: R: sptest SP06 strange behaviour
Michele Dekleva michele.dekleva at m3t.it
Wed Mar 25 15:13:30 UTC 2020
Hi Joel
My customer request me to use RTEMS 4.11.3 so i need to use this version.
Also consider that the FPGA based CortexM3 use a 133 MHz clock so I’m quite surprise that there could be problems with this CPU/clock.
Anyway, since by apply little modification to some tests (just like the ones I’ve indicated) all test complete correctly, from your point of view this solution could be considered valid in order to accept the BSP  ?
At the moment I don’t see any test failed because of a critical issue (such as a broken driver or incorrect time measurement): almost all problems are on synchronization between tasks, avoidable with minimal modifications on task’s source code.
Best Regards.
Dr. Michele Dekleva
Da: Joel Sherrill <joel at rtems.org>
Inviato: mercoledì 25 marzo 2020 14:20
A: Sebastian Huber <sebastian.huber at embedded-brains.de>
Cc: Michele Dekleva <michele.dekleva at m3t.it>; rtems-users at rtems.org <users at rtems.org>
Oggetto: Re: R: sptest SP06 strange behaviour
On Wed, Mar 25, 2020, 8:06 AM Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de> > wrote:
Hello Michele,
I am not sure if the RTEMS 4.11 test suite works with an interrupt
driven console driver. I would use the RTEMS master for new BSPs anyway.
You should use polled or the buffered test IO option. By using an interrupt driven console, you are introducing more scheduling points than the test was designed for.
FWIW I have never seen mass failures like yours from an interrupt driven console. It is usually just a few oddities in output order. Maybe the M3 is slow enough that things are skewed even versus the boards I remember from the early 90s.
But switching to the master is always good advice for new BSPs
--joel
users mailing list
users at rtems.org <mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
Questa e-mail è stata controllata per individuare virus con Avast antivirus.
https://www.avast.com/antivirus
URL: <http://lists.rtems.org/pipermail/users/attachments/20200325/34f0f50e/attachment-0001.html>
