R: R: sptest SP06 strange behaviour
Wed Mar 25 15:19:00 UTC 2020
Hello Michele,
On 25/03/2020 16:13, Michele Dekleva wrote:
> My customer request me to use RTEMS 4.11.3 so i need to use this version.
this makes little sense given that we are about to release RTEMS 5 soon.
> Also consider that the FPGA based CortexM3 use a 133 MHz clock so I’m
> quite surprise that there could be problems with this CPU/clock.
> Anyway, since by apply little modification to some tests (just like
> the ones I’ve indicated) all test complete correctly, from your point
> of view this solution could be considered valid in order to accept the
> BSP  ?
> At the moment I don’t see any test failed because of a critical issue
> (such as a broken driver or incorrect time measurement): almost all
> problems are on synchronization between tasks, avoidable with minimal
> modifications on task’s source code.
I would run the testsuite with the RTEMS master.
URL: <http://lists.rtems.org/pipermail/users/attachments/20200325/93980c6b/attachment.html>
