RTEMS tasks timesliced instead of running to completion. TIMESLICE flag is not active!
Thanassis Tsiodras (external) Thanassis.Tsiodras at esa.int
Fri May 1 08:13:17 UTC 2020
> Polled vs interrupt console drivers?
I don't see how...  With tasks spawned with RTEMS_DEFAULT_MODES and
CONFIGURE_MAXIMUM_PROCESSORS set to 1, Task 2 should not be allowed to run
until Task 1 completes - so the output of "Starting" ( in "task_begin" of
Task 2) should not be able to precede the output of "Computed" at the end
of Task1 - the relevant print should not have happened yet.
I can understand how console output can become garbled in tasks that are
running concurrently - but in this case, I would expect them to run in
sequence.
The only way for this
[TASK 0] Starting...
[TASK 0] Computed the correct floating point result.
[TASK 1] Starting...
[TASK 1] Computed the correct integer result.
[TASK 2] Starting...
[TASK 2] Computed the correct floating point result.
[TASK 3] Starting...
[TASK 3] Computed the correct integer result.
to turn into this
The expected result:
...is if indeed, the tasks are running concurrently with the ZynQ BSP.
So the question is:
Given the task spawning parameters ("RTEMS_DEFAULT_MODES") and
CONFIGURE_MAXIMUM_PROCESSORS set to 1, is it right to experience
timeslicing on the ZynQ ZC706?
Thanassis Tsiodras
Real-time Embedded Software Engineer
System, Software and Technology Department
ESTEC
Keplerlaan 1, PO Box 299
NL-2200 AG Noordwijk, The Netherlands
Thanassis.Tsiodras at esa.int | www.esa.int
T +31 71 565 5332
To:     "Thanassis Tsiodras (external)" <Thanassis.Tsiodras at esa.int>
Cc:     "Gedare Bloom" <gedare at rtems.org>, "rtems-users at rtems.org"
<users at rtems.org>, "Fernando Domínguez Pousa" <fdpousa at gmv.com>
Date:   01/05/2020 09:46
Subject:        Re: RTEMS tasks timesliced instead of running to
On 1/5/20 5:08 pm, Thanassis Tsiodras (external) wrote:
> Note that this test (complete code in
https://gitrepos.estec.esa.int/ttsiodras/RTEMS-build-workflows/-/tree/master/OAR
> creates the proper - non-interleaved - output when compiled and executed
> for the GR712RC and GR740 boards... but creates the interleaved output
> in a ZynQ ZC706 board.
This message is intended only for the recipient(s) named above. It may contain proprietary information and/or
protected content. Any unauthorised disclosure, use, retention or dissemination is prohibited. If you have received
this e-mail in error, please notify the sender immediately. ESA applies appropriate organisational measures to protect
personal data, in case of data privacy queries, please contact the ESA Data Protection Officer (dpo at esa.int).
URL: <http://lists.rtems.org/pipermail/users/attachments/20200501/be84dd1d/attachment.html>
