RTEMS tasks timesliced instead of running to completion. TIMESLICE flag is not active!
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Fri May 1 08:53:41 UTC 2020
Am 01.05.20 um 10:13 schrieb Thanassis Tsiodras (external):
> /> Polled vs interrupt console drivers?/
> I don't see how... With tasks spawned with RTEMS_DEFAULT_MODES and
> CONFIGURE_MAXIMUM_PROCESSORS set to 1, Task 2 should not be allowed to
> run until Task 1 completes - so the output of "Starting" ( in
> "task_begin" of Task 2) should not be able to precede the output of
> "Computed" at the end of Task1 - the relevant print should not have
> happened yet.
When the console driver works in interrupt mode and the output ring
buffer between the driver's base context and interrupt context is
filled, the driver's base context (and actually the calling task) waits
(and gets suspended) until there is space again in the output buffer.
So this is a point where the next task may start to execute.
Remember: doing I/O operations may often preempt a running task,
depending on the driver structure.
IMHO, relying on "NO_PREEMPT" as a way to avoid other tasks to run is
dangerous.
OTOH, I would expect more mingled output if this were the real cause for
the behavior seen. So there me a different cause for this.
wkr,
Thomas.
> I can understand how console output can become garbled in tasks that are
> running concurrently - but in this case, I would expect them to run in
> sequence.
> The only way for this
> [TASK 0] Starting...
> [TASK 0] Computed the correct floating point result.
> [TASK 1] Starting...
> [TASK 1] Computed the correct integer result.
> [TASK 2] Starting...
> [TASK 2] Computed the correct floating point result.
> [TASK 3] Starting...
> [TASK 3] Computed the correct integer result.
> to turn into this
> The expected result:
> ...is if indeed, the tasks are running concurrently with the ZynQ BSP.
> So the question is:
> Given the task spawning parameters ("RTEMS_DEFAULT_MODES") and
> CONFIGURE_MAXIMUM_PROCESSORS set to 1, is it right to experience
> timeslicing on the ZynQ ZC706?
> *Thanassis Tsiodras*
> Real-time Embedded Software Engineer
> System, Software and Technology Department
> *ESTEC*
> Keplerlaan 1, PO Box 299
> NL-2200 AG Noordwijk, The Netherlands
> Thanassis.Tsiodras at esa.int | www.esa.int
> T +31 71 565 5332
> From: "Chris Johns" <chrisj at rtems.org>
> To: "Thanassis Tsiodras (external)" <Thanassis.Tsiodras at esa.int>
> Cc: "Gedare Bloom" <gedare at rtems.org>, "rtems-users at rtems.org"
> <users at rtems.org>, "Fernando Domínguez Pousa" <fdpousa at gmv.com>
> Date: 01/05/2020 09:46
> Subject: Re: RTEMS tasks timesliced instead of running to
> On 1/5/20 5:08 pm, Thanassis Tsiodras (external) wrote:
>> Note that this test (complete code in
>> https://gitrepos.estec.esa.int/ttsiodras/RTEMS-build-workflows/-/tree/master/OAR)
>> creates the proper - non-interleaved - output when compiled and executed
>> for the GR712RC and GR740 boards... but creates the interleaved output
>> in a ZynQ ZC706 board.
> Chris
> This message is intended only for the recipient(s) named above. It may contain proprietary information and/or
> protected content. Any unauthorised disclosure, use, retention or dissemination is prohibited. If you have received
> this e-mail in error, please notify the sender immediately. ESA applies appropriate organisational measures to protect
> personal data, in case of data privacy queries, please contact the ESA Data Protection Officer (dpo at esa.int).
> users mailing list
> users at rtems.org
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available on request
