Interested in contributing to Beaglebone BSP
Christian Mauderer
christian.mauderer at embedded-brains.de
Tue May 5 06:08:55 UTC 2020
On 05/05/2020 06:38, Chris Johns wrote:
> On 4/5/20 12:50 am, Vijay Kumar Banerjee wrote:
>> On Sun, May 3, 2020 at 8:12 PM Christian Mauderer <oss at c-mauderer.de
>> <mailto:oss at c-mauderer.de>> wrote:
>> I don't think that would be a good idea before the release. After the
>> release we should work on a 1.6 build set.
> What about 5.2? :)
I don't have a problem adding it to the 5.2 release as a backport. But
currently I don't think that you would be happy about open patches for
5.1, correct?
>> The 1.6 only needs libyaml
>> (or libjson?) which is no default package on FreeBSD. So we need a
>> solution for that on FreeBSD hosts.
>> I didn't test it with FreeBSD. Yes, after the release we can make a best
>> for 1.6.0 and mention libjson/libyaml as a dependency. We'll just have
>> to figure out a way to check from RSB if the package is present, I hope
>> we'll find some example in the repo already.
> GDB and Python is a example. It is complicated so I hope it provides a
> suitable example....
> https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gdb-common-1.cfg#n70
> The `rtems-build-dep` script may help.
> In the bare devel/qemu build set there are checks against pkgconfig and
> if a library is not found on the host it is built for you.
> I hope this helps.
> Chris
> users mailing list
> users at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
