RTEMS Toolchain Building Error
Christian Mauderer christian.mauderer at embedded-brains.de
Wed May 13 06:27:49 UTC 2020
Hello Jianxun Yan,
On 12/05/2020 20:47, Jianxun Yan wrote:
> Dear all,
> Tried to build RTEMS 5 on Fedora 32 and got error.
>   * ../source-builder/sb-set-builder  --prefix=$HOME/development/rtems/5
>     5/rtems-arm
> Config: tools/rtems-gdb-9.1-1.cfg
> Package: arm-rtems5-gdb-9.1-x86_64-linux-gnu-1
> Building: arm-rtems5-gdb-9.1-x86_64-linux-gnu-1
> Error: building arm-rtems5-gdb-9.1-x86_64-linux-gnu-1
> Build FAILED
That's a really short error message. You might want to think about
adding the "--log=some_log_file.txt" option to your sb-set-builder call.
That will generate a really detailed (>40MB) log file for the whole
build. You'll be interested in the last maybe 80 lines of this file.
There should be some error message there that gives more details what
went wrong.
Best regards
Christian Mauderer
> Does anyone know what caused the problem?
> Thanks,
> J. Yan
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows 10
> users mailing list
> users at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
