RTEMS Toolchain Building Error
Joel Sherrill
joel at rtems.org
Wed May 13 12:01:15 UTC 2020
On Wed, May 13, 2020, 1:27 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello Jianxun Yan,
> On 12/05/2020 20:47, Jianxun Yan wrote:
> > Dear all,
> > Tried to build RTEMS 5 on Fedora 32 and got error.
> > * ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5
> > 5/rtems-arm
> > Config: tools/rtems-gdb-9.1-1.cfg
> > Package: arm-rtems5-gdb-9.1-x86_64-linux-gnu-1
> > Building: arm-rtems5-gdb-9.1-x86_64-linux-gnu-1
> > Error: building arm-rtems5-gdb-9.1-x86_64-linux-gnu-1
> > Build FAILED
> That's a really short error message. You might want to think about
> adding the "--log=some_log_file.txt" option to your sb-set-builder call.
> That will generate a really detailed (>40MB) log file for the whole
> build. You'll be interested in the last maybe 80 lines of this file.
> There should be some error message there that gives more details what
> went wrong.
The Users Manual has a specific set of packages that need to be installed.
Among them are development packages for zlib and python. Did you check that
list and make sure all were installed?
Christian is right that the more specific and detailed answer is in the
log. But it looks like you are missing development packages.
> Best regards
> Christian Mauderer
> > Does anyone know what caused the problem?
> > Thanks,
> > J. Yan
> > Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> > Windows 10
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200513/9c8aa94e/attachment.html>
