RTEMS Release Snapshot 5.0.0-m2005-2
Chris Johns
chrisj at rtems.org
Sun May 24 23:32:21 UTC 2020
On 25/5/20 4:43 am, Michael Davidsaver wrote:
> On 5/8/20 1:11 AM, Chris Johns wrote:
>> Hello,
>> I have uploaded release snapshot 5.0.0-m2005-2. The path is:
>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-2/
> The "sources" link is broken.
> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-2/souces
Thanks.
>> I hope this is the last snapshot before we branch for the RTEMS 5 release.
>> Please download, test and report any issues.
>> New to this snapshot are HTML release notes for RTEMS 5:
>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2005-2/#rtems-5.1-release-notes
>> Please have a look.
>> This is one of the most tested builds of RTEMS including hardware testing. You can view the build logs for just May 2020 in the build mailing list archives:
>> https://lists.rtems.org/pipermail/build/2020-May/date.html
>> I posted test results for the Beaglebone Black and Xilinx Zynq BSPs this week:
>> https://lists.rtems.org/pipermail/build/2020-May/014695.html
>> https://lists.rtems.org/pipermail/build/2020-May/014694.html
>> Finally and most importantly thank you to everyone who has worked over the last few weeks. It has been fantastic to get down to one ticket. The milestone can be viewed here:
>> https://devel.rtems.org/milestone/5.1
> I finally got around to trying this again.
> ../source-builder/sb-set-builder --prefix=$HOME/source/rtems/usr --log=i386.txt 5/bsps/pc
> appears to succeed. Even the bsdnet build.
Great and thanks for the feedback.
> Which raises the question of how to build the examples?
Which examples? The ones in RTEMS or the rtems-exmaples.git repo?
> The powerpc toolchain build succeeds
> ../source-builder/sb-set-builder --prefix=$HOME/source/rtems/usr --log=powerpc.txt 5/rtems-powerpc
> However, the bsdnet build is still failing with duplicate inline functions.
> I had a look and couldn't see any obvious way to resolve this. Neither
> definition is conditional, and neither header is included directly.
> ../source-builder/sb-set-builder --prefix=$HOME/source/rtems/usr --log=powerpc-mvme3100.txt \
> --host=powerpc-rtems5 --target=powerpc-rtems5 --with-rtems-bsp=mvme3100 5/rtems-kernel 5/rtems-libbsd
OK. I will take a look when I am back on releasing.
