Need help cleaning up git repository
Peter Dufault dufault at hda.com
Thu Nov 5 14:11:04 UTC 2020
I'm not as good at "git" as I should be.  I'd like some help cleaning up my git repository so that I can submit some changes.
In particular when I got started I committed some changes to my local copy of master without branching it, and then started merging changes on other branches against that.  So my RTEMS repository looks like this:
[dufault at gen6 rtems]$ git branch -rv
  origin/4.10   e3f6d35 cpukit/score: avoid NULL and races in priority mutex
  origin/4.11   a100457 leon,gr1553b: improve init check
  origin/4.8    48953df Remove (Obsolete).
  origin/4.9    344856b rpc: misaligned address exception in get_myaddress.c
  origin/5      7021c01 libfs/rfs: Check search bit map end on last bit
  origin/HEAD   -> origin/master
  origin/master 6823943 score: Fix unused parameter 'lock' warning
[dufault at gen6 rtems]$ git branch -v
  add-uart-to-beatnik a3559e9 put rtems_shell_move_left() in correct file.
  atsam-fixes         3926a46 Merge branch 'master' into atsam-fixes
  master              34f0ccb [ahead 17] Merge branch 'master' of git://git.rtems.org/rtems
* mvme5500-final      5f5f9c7 Merge branch 'master' into mvme5500-final
You can see that my master is ahead of origin/master, and my local branches that I'd like to clean up (e.g. mvme5500-final, atsam-fixes) also include those changes.
I think I want to do something like:
- Rename my local master branch to a branch name that is related to the changes I put in;
- Drop the changes I made that on that branch in the other branches, e.g mvme5500-final, atsam-fixes etc so that those branches are now based on origin/master and only have the changes related to what I was working on.
Any advice?
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/users/attachments/20201105/08d04e55/attachment.bin>
