Python problems on OS X
Andrew Butterfield
Andrew.Butterfield at scss.tcd.ie
Tue Nov 17 10:19:21 UTC 2020
I keep getting a python error when trying to build the tool suite on
OS X. The end of the error log is:
checking whether to use python... /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
checking for python... no
configure: error: no usable python found at /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
make[1]: *** [configure-gdb] Error 1
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex /Users/butrfeld/REPOS/esa-qual/modules/rsb/rtems/build/sparc-rtems6-gdb-0295dde-x86_64-apple-darwin19.6.0-1/do-build
error: building sparc-rtems6-gdb-0295dde-x86_64-apple-darwin19.6.0-1
What are the criteria for python to be "useable"?
I have removed all traces of non-native (brew) pythons that I can find.
I followed the virtual environment instructions in the rtems-central README.md
:- which python
:- which python3
/Library/Frameworks/Python.framework/Versions/3.8/bin/python3
My machine is running macOS Catalina 10.15.7
Any ideas?
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/
