rtems_bsd_initialize() in POSIX_Init and qemu-system-i386
Heinz Junkes
junkes at fhi-berlin.mpg.de
Fri Oct 2 08:13:05 UTC 2020
Yes, seems to be a problem with the e1000.
with "model=rtl8139” it works perfectly.
qemu-system-i386 -m 64 -no-reboot -serial stdio -display none -net nic,model=rtl8139,macaddr=0e:b0:ba:5e:ba:11 -net user,restrict=yes -append "--video=off --console=/dev/com1" -kernel libComTestHarness
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 2. Oct 2020, at 08:15, Chris Johns <chrisj at rtems.org> wrote:
> On 2/10/20 2:48 pm, Heinz Junkes wrote:
>> init01.exe does not initialize the network interface.
> Yes. It splits the problem.
>> I see the same delay with dhcpcd01.exe
> Are you using the e1000? Try rtl8139.
> I do not see these delays on real PC hardware or qemu with rtl8139.
> Chris
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20201002/ab64c081/attachment-0001.bin>
