rtems_bsd_initialize() in POSIX_Init and qemu-system-i386
Chris Johns
chrisj at rtems.org
Fri Oct 2 08:16:17 UTC 2020
On 2/10/20 6:13 pm, Heinz Junkes wrote:
> Yes, seems to be a problem with the e1000.
> with "model=rtl8139” it works perfectly.
Could you please raise a ticket? It would be interesting to know if this happens
on real hardware.
> qemu-system-i386 -m 64 -no-reboot -serial stdio -display none -net nic,model=rtl8139,macaddr=0e:b0:ba:5e:ba:11 -net user,restrict=yes -append "--video=off --console=/dev/com1" -kernel libComTestHarness
qemu-system-i386 -m 512M -no-reboot -serial mon:stdio -nographic -net
nic,model=rtl8139 -net vde,id=vde0,sock=/tmp/vde1 -kernel
build/i386-rtems6-pc686-default/dhcpcd01.exe -append '--console=/dev/com1
--printk=/dev/com1'
Using VDE :)
