RTEMS Network Stack and Managed Switch
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Thu Oct 8 15:24:51 UTC 2020
Richard,
what hardware/BSP are you running on?
Just a shot in the dark: It seems the system crashes in arplookup -> ...
-> svfprintf. Can it be that some networking routine tries to print a
message with floating point, but the FPU is disabled for the
corresponding task?
wkr,
Thomas.
Am 08.10.20 um 17:15 schrieb Richard.Glossop at L3Harris.com:
> We have discovered a problem with the RTEMS network stack reaching the
> RTEMS _Terminate function when the interfaces are attached to a managed
> switch (in this case a Cisco 3560).
> This does not occur with direct connections or when attached to a layer
> 2 unmanaged switch (NetGear or SMC). Of course the 3560 puts out a lot
> of traffic that a layer 2 switch does not (spanning tree, CDP etc….)
> So it seems the managed switch is putting out traffic that is bringing
> RTEMS down.
> Has anyone seen this behavior? Have you determined the root cause?
> I set a break point and caught the following backtrace:
> #0 0x6006ec90 0x60200180 <_Terminate+0x4>
> #1 0x6006ece0 0x602001e8 <_Internal_error+0x8>
> #2 0x600da250 0x60200248 <_svfprintf_r+0x14>
> #3 0x600d5810 0x60200420 <snprintf+0x58>
> #4 0x60073bac 0x60200508 <inet_ntop4+0x24>
> #5 0x60073e70 0x60200580 <inet_ntop+0x280>
> #6 0x60073b78 0x60200630 <inet_ntoa_r+0x1c>
> #7 0x60076340 0x60200698 <arplookup+0x78>
> #8 0x60076e34 0x60200710 <arpintr+0x20c>
> #9 0x6008861c 0x602007c0 <networkDaemon+0xa0>
> #10 0x60088164 0x60200828 <taskEntry+0x20>
> #11 0x6006d210 0x60200888 <_Thread_Entry_adaptor_numeric+0x8>
> #12 0x6006c464 0x602008e8 <_Thread_Handler+0x60>
> #13 0x6006c404 0x60200948 <_Thread_Handler+0>
> CONFIDENTIALITY NOTICE: This email and any attachments are for the sole
> use of the intended recipient and may contain material that is
> proprietary, confidential, privileged or otherwise legally protected or
> restricted under applicable government laws. Any review, disclosure,
> distributing or other use without expressed permission of the sender is
> strictly prohibited. If you are not the intended recipient, please
> contact the sender and delete all copies without reading, printing, or
> saving.
> users mailing list
> users at rtems.org
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available on request
