rtems-syms for dynamic load
Rotem Dror MTH rodror at iai.co.il
Thu Oct 22 06:32:55 UTC 2020
Hi
I'm trying to implement the example found in the user manual of RTEMS (see 9.7.3.3. Loadable Symbols on: https://docs.rtems.org/branches/master/user/exe/loader.html).
From this example, it seems that it is necessary to use rtems-syms application. This app is existing on the RCC version. But when I try to run it I get an error message: "cannot execute binary file" (on msys2 terminal).
I also tried to execute this app on CMD of windows and got a message that this file is not recognized as a command. And when I change the suffix to .exe I got an error that this file is 16 bit (??)/
Do you know why the file cannot run? And what can be done?
From where can I download the latest version of rtems-syms?
Thank you
Rotem
*********************************************************************************************** Please consider the environment before printing this email ! The information contained in this communication is proprietary to Israel Aerospace Industries Ltd. and/or third parties, may contain confidential or privileged information, and is intended only for the use of the intended addressee thereof. If you are not the intended addressee, please be aware that any use, disclosure, distribution and/or copying of this communication is strictly prohibited. If you receive this communication in error, please notify the sender immediately and delete it from your computer. Thank you. Visit us at: www.iai.co.il
URL: <http://lists.rtems.org/pipermail/users/attachments/20201022/01580fb8/attachment.html>
