Which documentation is relevant for testing?
Frank Kühndel frank.kuehndel at embedded-brains.de
Thu Oct 29 09:10:33 UTC 2020
Hello Chris,
On 10/19/20 7:46 AM, Chris Johns wrote:
> On 9/9/20 11:40 pm, Frank Kühndel wrote:
>> I want to acquaint myself with testing in RTEMS. I found two sources of
>> documentation on this topic:
>>   * the RTEMS User Manual Chapter "9. Testing"
>>     https://docs.rtems.org/branches/master/user/testing/index.html
> This is the relevant documentation.
>>   * and the file rtems-tools/doc/rtems-tester.txt
>>     https://git.rtems.org/rtems-tools/tree/doc/rtems-tester.txt
> This can be removed. It existed before we had a user manual.
Thank you for your answer.
Do you want me to produce a patch which removes this file or would that
be to bold of mine?
Greetings
Frank
