Which documentation is relevant for testing?
Thu Oct 29 12:30:13 UTC 2020
On Thu, Oct 29, 2020, 4:10 AM Frank Kühndel <
frank.kuehndel at embedded-brains.de> wrote:
> Hello Chris,
> On 10/19/20 7:46 AM, Chris Johns wrote:
> > On 9/9/20 11:40 pm, Frank Kühndel wrote:
> >> I want to acquaint myself with testing in RTEMS. I found two sources of
> >> documentation on this topic:
> >>   * the RTEMS User Manual Chapter "9. Testing"
> >>     https://docs.rtems.org/branches/master/user/testing/index.html
> > This is the relevant documentation.
> >>   * and the file rtems-tools/doc/rtems-tester.txt
> >>     https://git.rtems.org/rtems-tools/tree/doc/rtems-tester.txt
> > This can be removed. It existed before we had a user manual.
> Thank you for your answer.
> Do you want me to produce a patch which removes this file or would that
> be to bold of mine?
That wouldn't be bold if you also confirm that the Users Guide has all the
info that is in that document. :)
There is even a ticket for this:
https://devel.rtems.org/ticket/4146
Definitely appreciated.
--joel
> Greetings
> Frank
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20201029/cf76b221/attachment.html>
