undefined reference to `iflib_gen_mac', Ticket #3985
junkes junkes at fhi-berlin.mpg.de
Wed Sep 2 14:33:36 UTC 2020
Unfortunately I can't build EPICS with i386/pc686 (rtems5.1) and libbsd.
I know Ticket #3985, I made everything new. But unfortunately it does
not work:
/home/h1/GSOC/RTEMS//bin/i386-rtems5-gcc --pipe
-B/home/h1/GSOC/RTEMS/i386-rtems5/pc686/lib/ -specs bsp_specs -qrtems
-fasm   -mtune=pentiumpro -march=pentium                   -DUNIX
-O2 -g -ffunction-sections -fdata-sections   -Wall
-D__LINUX_ERRNO_EXTENSIONS__ -DHAVE_SOCKADDR_SA_LEN=1  -I. -I../O.Common
-I. -I. -I.. -I../../../../include/compiler/gcc
-I../../../../include/os/RTEMS -I../../../../include         -c
rtemsTestData.c
/home/h1/GSOC/RTEMS//bin/i386-rtems5-g++
-o libComTestHarness -static
-L/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc686
-mtune=pentiumpro -march=pentium -u POSIX_Init -Wl,-Ttext,0x100000
   epicsTypesTest.o epicsInlineTest1.o epicsInlineTest2.o
epicsInlineTest3.o epicsInlineTest4.o epicsCalcTest.o
epicsAlgorithmTest.o epicsMathTest.o epicsMMIOTest.o epicsEllTest.o
epicsEnvTest.o epicsEnvUnsetTest.o epicsErrlogTest.o epicsStdioTest.o
epicsStdlibTest.o epicsSockResolveTest.o epicsStringTest.o
epicsTimeTest.o epicsThreadTest.o epicsThreadClassTest.o
epicsThreadOnceTest.o epicsThreadPriorityTest.o epicsThreadPrivateTest.o
epicsThreadHooksTest.o epicsThreadPoolTest.o epicsExitTest.o
epicsTimerTest.o ringPointerTest.o ringBytesTest.o epicsEventTest.o
epicsMutexTest.o epicsSpinTest.o epicsAtomicTest.o macDefExpandTest.o
cvtFastTest.o macLibTest.o aslibtest.o taskwdTest.o blockingSockTest.o
epicsMessageQueueTest.o epicsStackTraceTest.o ipAddrToAsciiTest.o
osiSockTest.o epicsRunLibComTests.o epicsThreadPerform.o
epicsMaxThreads.o buckTest.o epicsAtomicPerform.o cvtFastPerform.o
epicsTimeZoneTest.o rtemsTestHarness.o rtemsTestData.o   -lCom       -lm
-lrtemsCom -lc -lrtemscpu  -ltftpfs -lbsd -lz -lm -lgcc
/home/h1/GSOC/RTEMS/lib/gcc/i386-rtems5/7.5.0/../../../../i386-rtems5/bin/ld:
/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc686/librtemsCom.a(rtems_config.o):/home/h1/GSOC/RTEMS/i386-rtems5/pc686/lib/include/bsp/nexus-devices.h:157:
undefined reference to `_bsd_lem_pcimodule_sys_init'
/home/h1/GSOC/RTEMS/i386-rtems5/pc686/lib/libbsd.a(iflib.c.18.o): in
function `iflib_pseudo_register':
/home/h1/GSOC/RTEMS_DEV/libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/net/iflib.c:4804:
/home/h1/GSOC/RTEMS/i386-rtems5/pc686/lib/libbsd.a(iflib.c.18.o):(.rodata.iflib_pseudo_methods+0x4):
undefined reference to `noop_attach'
/home/h1/GSOC/RTEMS/i386-rtems5/pc686/lib/libbsd.a(iflib.c.18.o):(.rodata.iflib_pseudo_methods+0xc):
undefined reference to `iflib_pseudo_detach'
collect2: error: ld returned 1 exit status
../../../../configure/RULES_BUILD:212: recipe for target
'libComTestHarness' failed
make[4]: *** [libComTestHarness] Error 1
I have made this new in this way:
  wget
https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/rtems-source-builder-5.1.tar.xz
  tar Jxf rtems-source-builder-5.1.tar.xz
  mv rtems-source-builder-5.1 rsb
  cd rsb/rtems
  ../source-builder/sb-set-builder --prefix=/home/h1/GSOC/RTEMS
5/rtems-i386
  wget
https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/rtems-5.1.tar.xz
  tar Jxf rtems-5.1.tar.xz
  mv rtems-5.1 rtems
  cd rtems
  ./rtems-bootstrap
  mkdir b-pc686
  cd b-pc686/
  ../../rtems/configure --target=i386-rtems5 --prefix=/home/h1/GSOC/RTEMS
--disable-networking --enable-posix --enable-cxx --enable-tests
--enable-rtemsbsp=pc686
  make all
  make install
  cd libbsd
  ./waf configure --prefix=/home/h1/GSOC/RTEMS --rtems-bsps=i386/pc686
--buildset=buildset/default.ini
  ./waf
  ./waf install
Heinz
