RTEMS 5.1: RSB --with-rtems-bspopts is not working as described.
Karel Gardas
karel.gardas at centrum.cz
Sun Sep 6 21:34:52 UTC 2020
Hi,
while playing with pc383 BSP on RTEMS 5.1 release I'm trying to set
various BSP's compile time options using RSB and it does not work.
E.g. command:
../source-builder/sb-set-builder
--prefix=$HOME/sfw/rtems/5.1-smp2-vga80x50-key-to-reset 5/bsps/pc
--with-rtems-tests --with-rtems-smp
--with-rtems-bspopts="BSP_VIDEO_80x50=1 BSP_PRESS_KEY_FOR_RESET=1"
fails with:
Build Set: Time 0:00:28.975685
Build Set: Time 0:03:36.556012
installing: 5/bsps/pc ->
/export/home/karel/sfw/rtems/5.1-smp2-vga80x50-key-to-reset
clean staging: 5/bsps/pc
Staging Size: 4.271GB
Build Set: Time 0:24:53.756984
Build Set: BSP_PRESS_KEY_FOR_RESET=1
error: no build set file found: BSP_PRESS_KEY_FOR_RESET=1.bset
Build Set: Time 0:00:00.000420
Build FAILED
and that's after BSP and bsd and packages are build so I guess there is
something wrong with passing BSP related options down to the BSP configure.
Please let me know if I'm doing anything wrong here or if this is
already known bug in RSB.
Thanks,
Karel
