RTEMS 5.1: RSB --with-rtems-bspopts is not working as described.
Sun Sep 6 22:09:46 UTC 2020
On 7/9/20 7:34 am, Karel Gardas wrote:
> Hi,
> while playing with pc383 BSP on RTEMS 5.1 release I'm trying to set
> various BSP's compile time options using RSB and it does not work.
> E.g. command:
> ../source-builder/sb-set-builder
> --prefix=$HOME/sfw/rtems/5.1-smp2-vga80x50-key-to-reset 5/bsps/pc
> --with-rtems-tests --with-rtems-smp
> --with-rtems-bspopts="BSP_VIDEO_80x50=1 BSP_PRESS_KEY_FOR_RESET=1"
> fails with:
> Build Set: Time 0:00:28.975685
> Build Set: Time 0:03:36.556012
> installing: 5/bsps/pc ->
> /export/home/karel/sfw/rtems/5.1-smp2-vga80x50-key-to-reset
> clean staging: 5/bsps/pc
> Staging Size: 4.271GB
> Build Set: Time 0:24:53.756984
> Build Set: BSP_PRESS_KEY_FOR_RESET=1
> error: no build set file found: BSP_PRESS_KEY_FOR_RESET=1.bset
> Build Set: Time 0:00:00.000420
> Build FAILED
> and that's after BSP and bsd and packages are build so I guess there is
> something wrong with passing BSP related options down to the BSP configure.
> Please let me know if I'm doing anything wrong here or if this is
> already known bug in RSB.
What you are doing looks fine. Could you please raise a ticket for the 5.2
milestone reporting this [1] ?
Thanks
[1] https://devel.rtems.org/newticket?version=5&milestone=5.2
