How to use lvgl on pc386 BSP.
Karel Gardas karel.gardas at centrum.cz
Mon Sep 7 09:33:33 UTC 2020
On 9/7/20 11:22 AM, Christian Mauderer wrote:
> Hello Karel,
> note that rtems-littlevgl is still quite new and most likely _only_ used
> on BBB and (with an external display driver) on the imx. I don't think
> anyone tried it on pc686.
Yes, I'm kind of aware of that.
> On 07/09/2020 11:06, Karel Gardas wrote:
>> Hello,
>> I'm trying to compile rtems-littlevgl on pc686 BSP from RTEMS 5.1
>> release built with RSB -- hence with libbsd compiled in.
>> I'm hitting following compilation failure:
>> ../../lv_drivers/indev/evdev.c:16:10: fatal error: dev/evdev/input.h: No
>> such file or directory
>>  #include <dev/evdev/input.h>
>> compilation terminated.
> I checked the evdev/input.h. That one should definitively be there if
> libbsd is installed. There is no condition for that file. Are you sure
> that libbsd is compiled and installed correctly? To check that please
> make sure that "libbsd.a" in the $PREFIX/i386-rtems5/pc686/lib directory
> exists.
$ ls -la sfw/rtems/5.1/i386-rtems5/pc686/lib/libbsd.a
-rw-r--r-- 1 karel karel 104094278 Aug 31 19:57
karel at silence:~$ find sfw/rtems/5.1 -name 'input.h'
karel at silence:~$
so looks like libbsd for BBB and for pc686 is really a bit different.
>> when I disable USE_BSD_EVDEV in build/i386-rtems5-pc686/lv_drv_conf.h I
>> hit following error:
>> ../../lv_drivers/display/fbdev.c:23:10: fatal error: sys/consio.h: No
>>  #include <sys/consio.h>
> Do you need the input devices? Or the libbsd framebuffer? Or only one of
> them?
I'm just playing with RTEMS stuff on PC. The hope is to get grab of the
platform in order to create some nice demo in Haskell -- which port is
slowly progressing.
So yes, first framebuffer output would be nice to have and then
including input devices. Testing on PCs, notebooks with their keyboards
and touchpads/trackpoints and desktop PC with USB keyboard/mouse and if
that's not supported well, then even with PS/2 keyboard/mouse.
> There is an option to compile without drivers in case you have a custom
> display connected.
I'm hoping in standard VESA framebuffer on pc686 BSP to work well for this.
Thanks,
Karel
