rtems_bsd_initialize() in POSIX_Init and qemu-system-i386
junkes
junkes at fhi-berlin.mpg.de
Tue Sep 29 14:31:31 UTC 2020
Hello Karel,
To apply the patch I have to install it manually, without rsb.
Unfortunately I encountered a problem with undefinded
symbols.
Here are my steps to create the bsp:
git clone https://github.com/RTEMS/rtems-source-builder.git
mv rtems-source-builder rsb
cd rsb
git checkout 5
cd rtems
../source-builder/sb-set-builder --prefix=$HOME/DBG/rtems5 5/rtems-i386
cd ../..
git clone https://github.com/RTEMS/rtems.git
cd rtems
git checkout 5
./rtems-bootstrap
cd ..
mkdir build
cd build/
mkdir b-pc686
cd b-pc686/
../../rtems/configure --target=i386-rtems5 --prefix=$HOME/DBG/rtems5
--disable-networking --enable-posix --enable-cxx --enable-tests
--enable-rtemsbsp=pc686
make all
make install
cd ../..
git clone https://github.com/RTEMS/rtems-libbsd.git
cd rtems-libbsd/
git checkout 5
git submodule init
git submodule update rtems_waf
./waf configure --prefix=$HOME/DBG/rtems5 --rtems-bsps=i386/pc686
--buildset=buildset/default.ini
./waf
Waf: Entering directory
`/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default'
[1824/1948] Linking build/i386-rtems5-pc686-default/arphole.exe
[1835/1948] Linking build/i386-rtems5-pc686-default/dhcpcd01.exe
[1837/1948] Linking build/i386-rtems5-pc686-default/dhcpcd02.exe
[1843/1948] Linking build/i386-rtems5-pc686-default/epoch01.exe
[1858/1948] Linking build/i386-rtems5-pc686-default/evdev01.exe
/home/h1/DBG/rtems5/lib/gcc/i386-rtems5/7.5.0/../../../../i386-rtems5/bin/ld:
./libbsd.a(if_em.c.18.o): in function `em_if_vlan_unregister':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3366:
undefined reference to `iflib_get_softc'
./libbsd.a(if_em.c.18.o): in function `em_if_vlan_register':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3354:
./libbsd.a(if_em.c.18.o): in function `em_if_watchdog_reset':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1847:
./libbsd.a(if_em.c.18.o): in function `em_if_debug':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4531:
./libbsd.a(if_em.c.18.o): in function `em_if_tx_queue_intr_enable':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1424:
./libbsd.a(if_em.c.18.o):/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1414:
more undefined references to `iflib_get_softc' follow
./libbsd.a(if_em.c.18.o): in function `em_if_get_counter':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4005:
undefined reference to `iflib_get_ifp'
./libbsd.a(if_em.c.18.o): in function `em_if_timer':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1736:
undefined reference to `iflib_admin_intr_deferred'
./libbsd.a(if_em.c.18.o): in function `em_if_media_status':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1529:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1534:
./libbsd.a(if_em.c.18.o): in function `em_handle_link':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1511:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1514:
./libbsd.a(if_em.c.18.o): in function `em_if_set_promisc':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1627:
./libbsd.a(if_em.c.18.o): in function `em_disable_promisc':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1651:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1652:
./libbsd.a(if_em.c.18.o): in function `em_if_mtu_set':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1196:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1197:
undefined reference to `iflib_get_softc_ctx'
./libbsd.a(if_em.c.18.o): in function `em_if_stop':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1865:
./libbsd.a(if_em.c.18.o): in function `igb_if_intr_disable':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3456:
./libbsd.a(if_em.c.18.o): in function `igb_if_intr_enable':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3438:
./libbsd.a(if_em.c.18.o): in function `em_if_msix_intr_assign':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1971:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1981:
undefined reference to `iflib_irq_alloc_generic'
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2011:
undefined reference to `iflib_softirq_alloc_generic'
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1983:
undefined reference to `iflib_get_dev'
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2049:
undefined reference to `iflib_irq_free'
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2052:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2036:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2039:
./libbsd.a(if_em.c.18.o): in function `em_free_pci_resources':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2200:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2202:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2209:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2206:
./libbsd.a(if_em.c.18.o): in function `em_print_debug_info':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4541:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4542:
./libbsd.a(if_em.c.18.o): in function `em_if_queues_free':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2935:
./libbsd.a(if_em.c.18.o): in function `em_if_rx_queues_alloc':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2893:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2905:
./libbsd.a(if_em.c.18.o): in function `em_if_tx_queues_alloc':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2844:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2870:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2857:
./libbsd.a(if_em.c.18.o): in function `em_if_detach':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1140:
./libbsd.a(if_em.c.18.o): in function `em_if_suspend':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1171:
./libbsd.a(if_em.c.18.o): in function `em_enable_wakeup':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3708:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3709:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3710:
./libbsd.a(if_em.c.18.o): in function `em_if_multi_set':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1680:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1681:
./libbsd.a(if_em.c.18.o): in function `em_if_attach_pre':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:775:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:776:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:780:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:781:
undefined reference to `iflib_get_media'
./libbsd.a(if_em.c.18.o): in function `em_identify_hardware':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1885:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1886:
./libbsd.a(if_em.c.18.o): in function `em_set_num_queues':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:714:
./libbsd.a(if_em.c.18.o): in function `em_allocate_pci_resources':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1910:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1911:
./libbsd.a(if_em.c.18.o): in function `em_setup_msix':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2235:
./libbsd.a(if_em.c.18.o): in function `em_get_wakeup':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3586:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3587:
./libbsd.a(if_em.c.18.o): in function `em_enable_vectors_82574':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4579:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4581:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1077:
undefined reference to `iflib_set_mac'
./libbsd.a(if_em.c.18.o): in function `em_reset':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2421:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2422:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2423:
./libbsd.a(if_em.c.18.o): in function `em_if_update_admin_status':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1742:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1744:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1829:
undefined reference to `iflib_link_state_change'
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1823:
./libbsd.a(if_em.c.18.o): in function `em_if_init':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1251:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1253:
./libbsd.a(if_em.c.18.o): in function `em_initialize_transmit_unit':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2972:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1312:
undefined reference to `iflib_get_rx_mbuf_sz'
./libbsd.a(if_em.c.18.o): in function `em_initialize_receive_unit':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3112:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3114:
./libbsd.a(if_em.c.18.o): in function `em_if_media_change':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1580:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1581:
./libbsd.a(if_em.c.18.o): in function `em_if_resume':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1182:
./libbsd.a(if_em.c.18.o): in function `em_if_attach_post':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1093:
./libbsd.a(if_em.c.18.o): in function `em_setup_interface':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2802:
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:2803:
./libbsd.a(if_em.c.18.o): in function `em_add_hw_stats':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4041:
./libbsd.a(if_em.c.18.o): in function `_bsd_em_intr':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1402:
./libbsd.a(if_em.c.18.o):(.rodata.igb_methods+0xc): undefined reference
to `iflib_device_probe'
./libbsd.a(if_em.c.18.o):(.rodata.igb_methods+0x14): undefined reference
to `iflib_device_attach'
./libbsd.a(if_em.c.18.o):(.rodata.igb_methods+0x1c): undefined reference
to `iflib_device_detach'
./libbsd.a(if_em.c.18.o):(.rodata.igb_methods+0x24): undefined reference
to `iflib_device_shutdown'
./libbsd.a(if_em.c.18.o):(.rodata.igb_methods+0x2c): undefined reference
to `iflib_device_suspend'
./libbsd.a(if_em.c.18.o):(.rodata.igb_methods+0x34): undefined reference
to `iflib_device_resume'
./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0xc): undefined reference
./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0x14): undefined reference
./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0x1c): undefined reference
./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0x24): undefined reference
./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0x2c): undefined reference
./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0x34): undefined reference
./libbsd.a(igb_txrx.c.18.o): in function `igb_isc_rxd_pkt_get':
/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/igb_txrx.c:433:
collect2: error: ld returned 1 exit status
Waf: Leaving directory
Build failed
-> task in 'arphole.exe' failed with exit status 1 (run with -v to
display more information)
-> task in 'dhcpcd01.exe' failed with exit status 1 (run with -v to
-> task in 'dhcpcd02.exe' failed with exit status 1 (run with -v to
-> task in 'evdev01.exe' failed with exit status 1 (run with -v to
[h1 at earth rtems-libbsd (5)]$
On 2020-09-28 21:53, Karel Gardas wrote:
> Could you be so kind and test attached patch? It basically reverses
> priority of PCI accessors and helps a lot my Thinkpad T400/T500 where
> BIOS accessors are slow and I/O are fast. I've been hit by the issue
> not
> on network, but while BSP tries to initialize its console -- it tries
> to
> find all the possible PCI UARTs and this hurt time-wise a lot.
> Please report if this helps or not. I've not submitted the patch as all
> my other machines do not provide PCI BIOS in RTEMS friendly way and
> RTEMS is using PCI I/O accessors by default on them -- so speed access.
> I've neither tested on qemu with nic so your report will be appreciated
> here.
> Thanks,
> Karel
> On 9/28/20 9:43 PM, junkes wrote:
>> I have a problem with rtems_bsd_initialize() in POSIX_Init() and qemu.
>> call of
>> sc = rtems_bsd_initialize();
>> assert(sc == RTEMS_SUCCESSFUL);
>> always takes about 45 seconds until it is finished.
>> The output of
>> nexus0: <RTEMS Nexus device>
>> pcib0 pcibus 0 on motherboard
>> pci0: <PCI bus> on pcib0
>> pci0: <bridge, HOST-PCI> at device 0.0 (no driver attached)
>> pci0: <bridge, PCI-ISA> at device 1.0 (no driver attached)
>> pci0: <mass storage, ATA> at device 1.1 (no driver attached)
>> pci0: <bridge> at device 1.3 (no driver attached)
>> pci0: <display, VGA> at device 2.0 (no driver attached)
>> em0: <Intel(R) PRO/1000 Network Connection> port 0xc000-0xc03f mem
>> 0xfebc0000-0xfebdffff irq 11 at device 3.0 on pci0
>> comes very fast, but then the system is "frozen" for about 45 seconds.
>> Then this output appears:
>> info: em0: Ethernet address: 0e:b0:ba:5e:ba:11
>> cpu0 on motherboard
>> The setting of
>> default_network_set_self_prio(RTEMS_MAXIMUM_PRIORITY - 1U);
>> seems to have no influence. I also did not understand the setting of
>> priorities.
>> CPU USAGE BY THREAD
>> ID | NAME | SECONDS |
>> PERCENT
>> 0x09010001 | IDLE | 46.042360
>> 98.800
>> 0x0a010001 | TIME | 0.000067
>> 0.000
>> 0x0a010002 | IRQS | 0.000969
>> 0.002
>> 0x0a010003 | swi6: task queu | 0.000000
>> 0.000
>> 0x0a010004 | config_0 | 0.000000
>> 0.000
>> 0x0a010005 | swi5: fast task | 0.000000
>> 0.000
>> 0x0a010006 | kqueue_ctx task | 0.000000
>> 0.000
>> 0x0a010007 | thread taskq | 0.000000
>> 0.000
>> 0x0a010008 | swi6: Giant tas | 0.000000
>> 0.000
>> 0x0a010009 | swi1: netisr 0 | 0.000000
>> 0.000
>> 0x0a01000a | if_io_tqg_0 | 0.000000
>> 0.000
>> 0x0a01000b | if_config_tqg_0 | 0.000000
>> 0.000
>> 0x0a01000c | softirq_0 | 0.000000
>> 0.000
>> 0x0b010001 | | 0.561695
>> 1.205
>> 0x0b010003 | | 0.001552
>> 0.003
>> TIME SINCE LAST CPU USAGE RESET IN SECONDS:
>> 46.608912
>> Task control block(Nr.: 1)
>> task control block at 0x006b33c0
>> task ID: 0x09010001
>> name_32: -- ELDI --
>> ID=0x09010001 name=IDLE
>> --Info (hpj)-- task Nr: 1
>> id=151060481, name=IDLE, prio = 255
>> Task control block(Nr.: 2)
>> task control block at 0x006ab8a0
>> task ID: 0x0a010001
>> name_32: -- EMIT --
>> ID=0x0a010001 name=TIME
>> --Info (hpj)-- task Nr: 2
>> id=167837697, name=TIME, prio = 98
>> Task control block(Nr.: 3)
>> task control block at 0x006abc38
>> task ID: 0x0a010002
>> name_32: -- SQRI --
>> ID=0x0a010002 name=IRQS
>> --Info (hpj)-- task Nr: 3
>> id=167837698, name=IRQS, prio = 96
>> Task control block(Nr.: 4)
>> task control block at 0x006abfd0
>> task ID: 0x0a010003
>> name_32: -- DSB_ --
>> ID=0x0a010003 name=_BSD
>> --Info (hpj)-- task Nr: 4
>> id=167837699, name=swi6: task queu, prio = 100
>> Task control block(Nr.: 5)
>> task control block at 0x006ac368
>> task ID: 0x0a010004
>> name_32: -- DSB_ --
>> ID=0x0a010004 name=_BSD
>> --Info (hpj)-- task Nr: 5
>> id=167837700, name=config_0, prio = 100
>> Task control block(Nr.: 6)
>> task control block at 0x006ac700
>> task ID: 0x0a010005
>> name_32: -- DSB_ --
>> ID=0x0a010005 name=_BSD
>> --Info (hpj)-- task Nr: 6
>> id=167837701, name=swi5: fast task, prio = 100
>> Task control block(Nr.: 7)
>> task control block at 0x006aca98
>> task ID: 0x0a010006
>> name_32: -- DSB_ --
>> ID=0x0a010006 name=_BSD
>> --Info (hpj)-- task Nr: 7
>> id=167837702, name=kqueue_ctx task, prio = 100
>> Task control block(Nr.: 8)
>> task control block at 0x006ace30
>> task ID: 0x0a010007
>> name_32: -- DSB_ --
>> ID=0x0a010007 name=_BSD
>> --Info (hpj)-- task Nr: 8
>> id=167837703, name=thread taskq, prio = 100
>> Task control block(Nr.: 9)
>> task control block at 0x006ad1c8
>> task ID: 0x0a010008
>> name_32: -- DSB_ --
>> ID=0x0a010008 name=_BSD
>> --Info (hpj)-- task Nr: 9
>> id=167837704, name=swi6: Giant tas, prio = 100
>> Task control block(Nr.: 10)
>> task control block at 0x006ad560
>> task ID: 0x0a010009
>> name_32: -- DSB_ --
>> ID=0x0a010009 name=_BSD
>> --Info (hpj)-- task Nr: 10
>> id=167837705, name=swi1: netisr 0, prio = 100
>> Task control block(Nr.: 11)
>> task control block at 0x006ad8f8
>> task ID: 0x0a01000a
>> name_32: -- DSB_ --
>> ID=0x0a01000a name=_BSD
>> --Info (hpj)-- task Nr: 11
>> id=167837706, name=if_io_tqg_0, prio = 100
>> Task control block(Nr.: 12)
>> task control block at 0x006adc90
>> task ID: 0x0a01000b
>> name_32: -- DSB_ --
>> ID=0x0a01000b name=_BSD
>> --Info (hpj)-- task Nr: 12
>> id=167837707, name=if_config_tqg_0, prio = 100
>> Task control block(Nr.: 13)
>> task control block at 0x006ae028
>> task ID: 0x0a01000c
>> name_32: -- DSB_ --
>> ID=0x0a01000c name=_BSD
>> --Info (hpj)-- task Nr: 13
>> id=167837708, name=softirq_0, prio = 100
>> Task control block(Nr.: 14)
>> task control block at 0x006a3d20
>> task ID: 0x0b010001
>> name_32: -- --
>> ID=0x0b010001 name=
>> --Info (hpj)-- task Nr: 14
>> id=184614913, name=, prio = 30
>> Task control block(Nr.: 15)
>> task control block at 0x006a4450
>> task ID: 0x0b010003
>> name_32: -- --
>> ID=0x0b010003 name=
>> --Info (hpj)-- task Nr: 15
>> id=184614915, name=, prio = 229
>> qemu is called with:
>> qemu-system-i386 -m 64 -no-reboot -serial stdio -display none -net
>> nic,model=e1000,macaddr=0e:b0:ba:5e:ba:11 -net user,restrict=yes
>> -append
>> "--video=off --console=/dev/com1" -kernel libComTestHarness
>> Heinz
>> users mailing list
>> users at rtems.org
