rtems_bsd_initialize() in POSIX_Init and qemu-system-i386
Karel Gardas
karel.gardas at centrum.cz
Tue Sep 29 15:48:21 UTC 2020
Jan Sommer helped me with this in the past:
https://lists.rtems.org/pipermail/users/2020-September/067871.html
On 9/29/20 4:31 PM, junkes wrote:
> [1858/1948] Linking build/i386-rtems5-pc686-default/evdev01.exe
> /home/h1/DBG/rtems5/lib/gcc/i386-rtems5/7.5.0/../../../../i386-rtems5/bin/ld:
> ./libbsd.a(if_em.c.18.o): in function `em_if_vlan_unregister':
> /home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3366:
> undefined reference to `iflib_get_softc'
> ./libbsd.a(if_em.c.18.o): in function `em_if_vlan_register':
> /home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:3354:
> ./libbsd.a(if_em.c.18.o): in function `em_if_watchdog_reset':
> /home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1847:
> ./libbsd.a(if_em.c.18.o): in function `em_if_debug':
> /home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:4531:
> ./libbsd.a(if_em.c.18.o): in function `em_if_tx_queue_intr_enable':
> /home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1424:
> ./libbsd.a(if_em.c.18.o):/home/h1/DBG/dev5/rtems-libbsd/build/i386-rtems5-pc686-default/../../freebsd/sys/dev/e1000/if_em.c:1414:
> more undefined references to `iflib_get_softc' follow
