$ ./waf bsp_list --rtems-bsps=sparc/ doesn't work
Mr. Andrei Chichak groups at chichak.ca
Tue Aug 3 21:54:42 UTC 2021
I’m going through the docs at https://docs.rtems.org/branches/master/user/bld/index.html <https://docs.rtems.org/branches/master/user/bld/index.html> and section 7.3.2 BSP List has a broken command
./waf bsp_list
Works nicely, but adding the —rtems-bsps=  param to it always gives the result:
No BSP matches with the specified patterns: 'sparc/'
whatever pattern you give it.
(master head)
Andrei
URL: <http://lists.rtems.org/pipermail/users/attachments/20210803/443adc5d/attachment.html>
