$ ./waf bsp_list --rtems-bsps=sparc/ doesn't work
Christian MAUDERER
christian.mauderer at embedded-brains.de
Wed Aug 4 14:56:57 UTC 2021
Hello Andrei,
Am 03.08.21 um 23:54 schrieb Mr. Andrei Chichak:
> I’m going through the docs at
> https://docs.rtems.org/branches/master/user/bld/index.html
> <https://docs.rtems.org/branches/master/user/bld/index.html> and section
> 7.3.2 BSP List has a broken command
> ./waf bsp_list
> Works nicely, but adding the —rtems-bsps= param to it always gives the
> result:
> No BSP matches with the specified patterns: 'sparc/'
> whatever pattern you give it.
> (master head)
> Andrei
Thanks for reporting this. I checked the wscript and it seems that the
patterns are used as python regexes but with an added "$". So if you use
a pattern like 'sparc/', the names will be tested for 'sparc/$'. I
assume that this is the case to correctly handle BSPs like
riscv/rv64imac
riscv/rv64imac_medany
Without the $ the first one would include the second one.
So you have to use
./waf bsp_list --rtems-bsps='sparc/.*'
or
./waf bsp_list --rtems-bsps='sparc/.*,sh/.*'
Do you want to create a patch for the documentation? That would be this
file: https://git.rtems.org/rtems-docs/tree/user/bld/index.rst
Best regards
Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
