Chat
Tue Aug 10 14:58:36 UTC 2021
On Tue, Aug 10, 2021 at 5:34 AM Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> Hi Benson,
> Regarding Discord for RTEMS, here you go: https://discord.gg/TKhmGt8p.
> Best,
> Kuan-Hsun
> On Tue, Aug 10, 2021 at 1:21 PM Mathew Benson <mbenson at windhoverlabs.com>
> wrote:
>> Is there a Slack or Discord channel to discuss RTEMS?  I don't want to
>> flood everybody's inbox with emails.
As well, for this kind of development work (porting RTEMS), you can bring
your discussions and questions over to devel at rtems.org.
> I want to port RTEMS to the Xilinx Zynq Ultrascale+ R5.  I've taken the
>> RTEMS training, but that was a couple years ago.  I think I'll be fine once
>> I can just get through the build system and can focus on just code, but the
>> build system seems very foreign to me.  There still seems to be either
>> fragments of an old build system or just files that don't seem to serve any
>> purpose.  It would appear that "/spec/build/bsps/arm/xilinx-zynqmp" is
>> where my build set definition begins, but then what is
>> "/bsps/arm/xilinx-zynqmp/config" for?
We haven't quite divorced ourselves from the older autotools build system,
but new BSPs/ports (including the aarch64) are not using the old build
system at all.
The arm/xilinx-zynqmp is a BSP for only the 32-bit arm support of the Zynq
Ultrascale+ MPSOC specifically tested/used on the Ultra96. It was
contributed by Dornerworks. I guess this is a little confusing, because now
we also have bsps/aarch64/xilinx-zynqmp, which provides the 64-bit support.
At some point, we should be able to deprecate/drop the arm/xilinx-zynqmp
with the ability to configure the aarch64/xilinx-zynqmp to only run in
aarch32 mode.
> Also, everything still seems to be organized by architecture, the board.
>> How do you want the Zynq Ultrascale organized?  It has multiple
>> architectures on the same SoC.  Should it be under "arm" or "aarch64"?  Is
>> it possible to build two kernels in a single step, or should it contain an
>> entry in "arm" for the R5 and an entry in "aarch64" for the A53?
It will be preferred to work on the aarch64 version for the A53 processor.
The R5 as a standalone would be a BSP under arm though.
>> *Mathew Benson*
>> CEO | Chief Engineer
>> Windhover Labs, LLC
>> 832-640-4018
>> www.windhoverlabs.com
>> users mailing list
>> users at rtems.org
> Diese Mail wurde mobil geschrieben. Etwaige Rechtschreibfehler sind volle
> Absicht und als großzügiges Geschenk zu verstehen.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210810/f6aeb8b6/attachment.html>
