Chat
Kuan-Hsun Chen c0066c at gmail.com
Tue Aug 10 11:33:24 UTC 2021
Hi Benson,
Regarding Discord for RTEMS, here you go: https://discord.gg/TKhmGt8p.
Best,
Kuan-Hsun
On Tue, Aug 10, 2021 at 1:21 PM Mathew Benson <mbenson at windhoverlabs.com>
wrote:
> Is there a Slack or Discord channel to discuss RTEMS?  I don't want to
> flood everybody's inbox with emails.
> I want to port RTEMS to the Xilinx Zynq Ultrascale+ R5.  I've taken the
> RTEMS training, but that was a couple years ago.  I think I'll be fine once
> I can just get through the build system and can focus on just code, but the
> build system seems very foreign to me.  There still seems to be either
> fragments of an old build system or just files that don't seem to serve any
> purpose.  It would appear that "/spec/build/bsps/arm/xilinx-zynqmp" is
> where my build set definition begins, but then what is
> "/bsps/arm/xilinx-zynqmp/config" for?
> Also, everything still seems to be organized by architecture, the board.
> How do you want the Zynq Ultrascale organized?  It has multiple
> architectures on the same SoC.  Should it be under "arm" or "aarch64"?  Is
> it possible to build two kernels in a single step, or should it contain an
> entry in "arm" for the R5 and an entry in "aarch64" for the A53?
> *Mathew Benson*
> CEO | Chief Engineer
> Windhover Labs, LLC
> 832-640-4018
> www.windhoverlabs.com
> users mailing list
> users at rtems.org
Diese Mail wurde mobil geschrieben. Etwaige Rechtschreibfehler sind volle
Absicht und als großzügiges Geschenk zu verstehen.
URL: <http://lists.rtems.org/pipermail/users/attachments/20210810/33017261/attachment.html>
