RTEMS5 checksum failure file: sources/jpegsrc.v9a
Mon Feb 1 17:36:38 UTC 2021
Indeed. It seems the sha512 has changed. The file doesn't appear to be
different on the http server. I found a copy at
https://download.videolan.org/contrib/jpeg/ that has a matching sha512sum
as we expect in the RSB.
I compared those two tar files, and found this:
--rw-r--r-- 1 gedare gedare   4807 May  2  2010 makejvcx.v10
--rw-r--r-- 1 gedare gedare   3595 May  2  2010 makecvcx.v10
--rw-r--r-- 1 gedare gedare   3595 May  2  2010 makedvcx.v10
--rw-r--r-- 1 gedare gedare   2876 May  2  2010 makervcx.v10
--rw-r--r-- 1 gedare gedare   3535 May  2  2010 maketvcx.v10
--rw-r--r-- 1 gedare gedare   2876 May  2  2010 makewvcx.v10
--rw-r--r-- 1 gedare gedare   2288 May  2  2010 makecfil.v10
--rw-r--r-- 1 gedare gedare   2288 May  2  2010 makedfil.v10
--rw-r--r-- 1 gedare gedare   1142 May  2  2010 makerfil.v10
--rw-r--r-- 1 gedare gedare   2123 May  2  2010 maketfil.v10
--rw-r--r-- 1 gedare gedare   1142 May  2  2010 makewfil.v10
--rw-r--r-- 1 gedare gedare   1859 May  1  2010 makeasln.v10
--rw-r--r-- 1 gedare gedare    679 May  1  2010 makejsln.v10
--rw-r--r-- 1 gedare gedare   5789 May  1  2010 makejfil.v10
+-rw-r--r-- 1 gedare gedare   4804 May  2  2010 makejvcx.v10
+-rw-r--r-- 1 gedare gedare   3592 May  2  2010 makecvcx.v10
+-rw-r--r-- 1 gedare gedare   3592 May  2  2010 makedvcx.v10
+-rw-r--r-- 1 gedare gedare   2873 May  2  2010 makervcx.v10
+-rw-r--r-- 1 gedare gedare   3532 May  2  2010 maketvcx.v10
+-rw-r--r-- 1 gedare gedare   2873 May  2  2010 makewvcx.v10
+-rw-r--r-- 1 gedare gedare   2285 May  2  2010 makecfil.v10
+-rw-r--r-- 1 gedare gedare   2285 May  2  2010 makedfil.v10
+-rw-r--r-- 1 gedare gedare   1139 May  2  2010 makerfil.v10
+-rw-r--r-- 1 gedare gedare   2120 May  2  2010 maketfil.v10
+-rw-r--r-- 1 gedare gedare   1139 May  2  2010 makewfil.v10
+-rw-r--r-- 1 gedare gedare   1856 May  1  2010 makeasln.v10
+-rw-r--r-- 1 gedare gedare    676 May  1  2010 makejsln.v10
+-rw-r--r-- 1 gedare gedare   5786 May  1  2010 makejfil.v10
It appears that someone has removed some unicode characters or similar (
<8b>¯¨ ) from the file header line
+<?xml version="1.0" encoding="utf-8"?>
of all these .v10 files in the ijg.org download, without somehow modifying
the file metadata.
On Mon, Feb 1, 2021 at 1:03 AM Matt Rippa <mrippa at gemini.edu> wrote:
> Hi all,
> I have a quick test here that fails. This worked a few weeks ago.
> Thanks,
> -Matt
> mkdir quick-test
> cd quick-test/
> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> cd rsb/
> git checkout 5
> cd rtems
> ../source-builder/sb-set-builder --source-only-download 5/bsps/pc
> RTEMS Source Builder - Set Builder, 5 (803d42cda7b3)
> Build Set: 5/bsps/pc
> Build Set: 5/rtems-i386.bset
> Build Set: 5/rtems-autotools.bset
> Build Set: 5/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> package: autoconf-2.69-x86_64-linux-gnu-1
> Creating source directory: sources
> download: https://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz ->
> sources/autoconf-2.69.tar.gz
> downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
> config: tools/rtems-automake-1.12.6-1.cfg
> ...SNIP...
> Build Set: graphics/libjpeg.bset
> config: graphics/libjpeg-9a-1.cfg
> package: libjpeg-v9a-i386-rtems5-1
> download: http://www.ijg.org/files/jpegsrc.v9a.tar.gz ->
> sources/jpegsrc.v9a.tar.gz
> downloading: sources/jpegsrc.v9a.tar.gz - 976.5kB of 976.5kB (100%)
> warning: checksum error: jpegsrc.v9a.tar.gz
> error: checksum failure file: sources/jpegsrc.v9a.tar.gz
> Build FAILED
> Build Set: Time 0:00:01.201104
> Build Set: Time 0:00:05.636248
> Build Set: Time 0:01:05.610093
> Build FAILED
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210201/b93f930f/attachment.html>
