Trouble with addr_abort exception on arm/imx7 BSP with simple RTEMS code
Christian Mauderer
oss at c-mauderer.de
Sun Feb 7 19:35:52 UTC 2021
Hello Stefan,
On 07/02/2021 19:31, Stefan Akatyschew wrote:
> Hey Christian,
> no problem, thanks a lot for your reply!
> Here it starts, right after loading the elf file:
> Just to be sure there is no mistake in my setup, I attached the complete
> listing shown (start.S), as well as my .cmm script to load the binary.
That looks like there is a bug in the setup of your debugger.
The i.MX7 BSP normally runs out of SDRAM. It expects to be started by a
U-Boot on the i.MX7. If I understand your trace script correctly, it
resets the board, then it loads the application. This will try to put
the application into a SDRAM that is not yet initialized. It's a bit odd
that Trace32 doesn't throw an error when you try to access the code there.
For boards with a boot loader (like U-Boot) I most of the time use the
following approach:
- Make sure that there is an application that can be loaded by the boot
loader (Linux Kernel, RTEMS application, ...)
- If the BSP needs an FDT (i.MX does need one): Make sure that one is
loaded too.
In the debug script:
- Reset and halt the board
- Set a breakpoint at the location where the Kernel would start (in that
case 0x80200000; for Linux maybe 0x80000000 - check the U-Boot output
for that)
- Start the board and let it run till the breakpoint. This will execute
the boot loader and let it do all the basic setup.
- Load the application for debugging.
- Let the CPU run.
I can take a look whether I have some debug script for an i.MX7 on my
work PC tomorrow.
> Another question, I wonder why when I run waf configure, it tells me
> "Checking for RTEMS_SMP : no", when I built my BSP
> with the option "--with-rtems-smp"?
--with-rtems-smp was for the old make based build system. For the waf
based one I think you have to set RTEMS_SMP = True in the config.ini.
Where did you find the --with-rtems-smp switch? It's quite possible that
there is a there a bug in the documentation?
> On this occasion also, in case you missed it, the ssl certificate for
> ftp.rtems.org expired a few days ago.
I forwarded the information to our internal list. There has been just
recently a certificate update for devel.rtems.org. Most likely the
ftp.rtems.org has been missed.
Best regards
Christian
> Kind regards,
> Stefan
> On Feb 6 2021, at 12:38 pm, Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Stefan,
> sorry for not answering earlier. I somehow missed the mail.
> On 02/02/2021 18:02, Stefan Akatyschew wrote:
> > Hey together!
> > I'm new to RTEMS and just hit some errors, I just can't figure out.
> > Since I will probably lure around a bit longer, I wanted to give
> short
> > introduction, so you can estimate what to expect from me: I'm a
> > nearly-finished(tm) EE undergrad from Germany, not having any
> hands-on
> > experience on RTOS, my embedded knowledge is confined to some hobby
> > STM32/PIC projects and the usual microcontroller stuff they teach at
> > uni. Not a great starting point for something as advanced as
> RTEMS, I'm
> > aware, but I'm eager to learn it. Besides embedded stuff I'm also
> into
> > the RF electronics :)
> It's not a too bad starting point either. It's quite similar to the one
> I had when I had my first contact with RTEMS.
> > Goal of my engagement with RTEMS: Setting up a small SMP Demo
> > Application on the Phytec Zeta i.MX7d Board
> > https://www.phytec.eu/product-eu/single-board-computer/phyboard-zeta/
> > for a university project, though after getting to know RTEMS, I
> hope to
> > be able to stick around after that, the applications in
> (aero)space, are
> > exactly what I'm passionate about! Also I hope after I get to run
> > everything, I can compile and publish my documentation/experience to
> > help others with the i.MX 7, since the road has been rather rocky
> for me
> > now.
> I hope I didn't add too much stones to the road. I worked quite a bit on
> the imx BSP when I added i.MX 6 and some of the changes haven't been
> extensively tested on i.MX 7.
> > So to my actual problem: I have the before mentioned i.MX 7d
> Board and a
> > Lauterbach Power Debug Interface with trace32, to directly flash my
> > binaries onto the SRAM. I'm using their i.MX7d SABRE
> configuration file,
> > which successfully worked with their sample binary and slightly
> modified
> > it (mainly deactivating ETF on-chip tracing).
> > I've built the RTEMS 5 toolchain according to your quick-start
> guide (
> > https://docs.rtems.org/branches/master/user/start/index.html),
> with some
> > slight modifications arm/imx7 on my Ubuntu 18.04 VM (kernel built
> from
> > sources, somehow didn't work otherwise). I also built the
> simplest demo
> > application from 2.7, which went without problems (well, after many
> > hours of troubleshooting stupid mistakes). Now after flashing the
> binary
> > directly to the SRAM with my Lauterbach Debugger (without RTEMS OS
> > Awareness yet), I end up in the exception routine
> > "_ARMV4_Exception_data_abort_default", with the following
> > call-tree-hierarchy:
> Can you hit "Up" once and take a look at the code location and send a
> screen shot. Best thing would be the mode that shows assembler
> istructions too. And maybe the window with the CPU registers.
> Best regards
> Christian
> > I also tried removing the printf (just letting it count an integer up
> > and overflow), since I was confused why RTEMS would call a uart_write
> > function otherwise, but that didn't change anything and actually
> doesn't
> > even get to the Init rtems_task.
> > I already looked on the internet, the documentation and the
> mailing-list
> > archive for help (not nearly finished reading through the complete
> > Classic API Guide and User Manual, that'll take some time).
> > Unfortunately I'm also new to the Lauterbach Debugger, which
> seems to be
> > a beast of its own, so I unfortunately can't provide any useful
> on-chip
> > trace data yet. I hope anyone can point me to the, probably rather
> > obvious, mistake I'm making, any help is appreciated!
> > Last but not least, thanks for your awesome work on RTEMS!
> > Kind regards,
> > Stefan
> > Attached some maybe useful outputs:
> > stefan at rtems-vm:~$ arm-rtems5-gcc --version
> > arm-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1, Newlib
> 7947581)
> > ./waf configure --rtems=$HOME/rtems/5 --rtems-bsp=arm/imx7
> > Setting top to :
> > /home/stefan/VCS/rtems-bp/first-test
> > Setting out to :
> > /home/stefan/VCS/rtems-bp/first-test/build
> > RTEMS Version : 5
> > Architectures : arm-rtems5
> > Board Support Package (BSP) : arm-rtems5-imx7
> > Show commands : no
> > Long commands : no
> > Checking for program 'arm-rtems5-gcc' :
> > /home/stefan/rtems/5/bin/arm-rtems5-gcc
> > Checking for program 'arm-rtems5-g++' :
> > /home/stefan/rtems/5/bin/arm-rtems5-g++
> > Checking for program 'arm-rtems5-ld' :
> > /home/stefan/rtems/5/bin/arm-rtems5-ld
> > Checking for program 'arm-rtems5-ar' :
> > /home/stefan/rtems/5/bin/arm-rtems5-ar
> > Checking for program 'arm-rtems5-nm' :
> > /home/stefan/rtems/5/bin/arm-rtems5-nm
> > Checking for program 'arm-rtems5-objdump' :
> > /home/stefan/rtems/5/bin/arm-rtems5-objdump
> > Checking for program 'arm-rtems5-objcopy' :
> > /home/stefan/rtems/5/bin/arm-rtems5-objcopy
> > Checking for program 'arm-rtems5-readelf' :
> > /home/stefan/rtems/5/bin/arm-rtems5-readelf
> > Checking for program 'arm-rtems5-strip' :
> > /home/stefan/rtems/5/bin/arm-rtems5-strip
> > Checking for program 'arm-rtems5-ranlib' :
> > /home/stefan/rtems/5/bin/arm-rtems5-ranlib
> > Checking for program 'rtems-ld' :
> > /home/stefan/rtems/5/bin/rtems-ld
> > Checking for program 'rtems-tld' :
> > /home/stefan/rtems/5/bin/rtems-tld
> > Checking for program 'rtems-syms' :
> > /home/stefan/rtems/5/bin/rtems-syms
> > Checking for program 'rtems-bin2c' :
> > /home/stefan/rtems/5/bin/rtems-bin2c
> > Checking for program 'tar' : /bin/tar
> > Checking for program 'gcc, cc' :
> > Checking for program 'ar' :
> > Checking for program 'g++, c++' :
> > Checking for program 'gas, gcc' :
> > Checking for c flags '-MMD' : yes
> > Checking for cxx flags '-MMD' : yes
> > Compiler version (arm-rtems5-gcc) : 7.5.0 20191114 (RTEMS
> 5, RSB
> > 5.1, Newlib 7947581)
> > Checking for a valid RTEMS BSP installation : yes
> > Checking for RTEMS_DEBUG : no
> > Checking for RTEMS_MULTIPROCESSING : no
> > Checking for RTEMS_NEWLIB : yes
> > Checking for RTEMS_POSIX_API : yes
> > Checking for RTEMS_NETWORKING : yes
> > 'configure' finished successfully (1.056s)
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
