AW: RTEMS mkimage.py for U-Boot scripts
Chris Johns
chrisj at rtems.org
Thu Feb 11 21:53:49 UTC 2021
On 12/2/21 2:31 am, Andre.Nahrwold at dlr.de wrote:
> There has been a small typo in the previous patch.
Thank you for the patch. Could you please send it as a git patch to
devel at rtems.org or attach it to a ticket in Trac?
This may help ...
https://docs.rtems.org/branches/master/eng/vc-users.html?highlight=commit#creating-a-patch
Thanks
> -----Ursprüngliche Nachricht-----
> Von: users <users-bounces at rtems.org> Im Auftrag von Andre.Nahrwold at dlr.de
> Gesendet: Donnerstag, 11. Februar 2021 16:14
> An: users at rtems.org
> Betreff: AW: RTEMS mkimage.py for U-Boot scripts
> Hello,
> after some digging I think I found the problem and at least a workaround.
> As a disclaimer, I do not know if this really counts as a general fix.
> I have not invested enough time to dig through the original mkimage U-Boot source to figure this out.
> But I have attached my workaround patch if anyone might face the same problems.
> The source of the problem are eight bytes between the header and the actual input file which are missing when using mkimage.py.
> Also the input size and input crc are wrong which is a result of the missing bytes.
> These eight bytes always reflect the actual size of the input file (first four bytes) with four bytes zeros following.
> Within the original mkimage tool these eight bytes are considered part of the input file section in the output file.
> Therefore the calculated input size is eight bytes higher and the input crc differs.
> As a workaround the mkimage.py script will add these eight bytes to the output file and the input crc calculation and adjusts the input size.
> This only happens when the type script was selected.
> Best regards
> André
> Gesendet: Dienstag, 26. Januar 2021 08:09
> Betreff: RTEMS mkimage.py for U-Boot scripts
> Hello,
> in our laboratory setup we use different U-Boot scripts to control the boot behavior of our development board (Trenz TE0715 [1] on top of Trenz TE0706 [2]).
> These simple scripts need to be converted into a script image using the mkimage command for U-Boot. [3] We use the following command which works fine:
> ./mkimage -A arm -T script -C none -n "fancy name" -d bootscripts/rtems rtems.img
> Image Name: fancy name
> Created: Tue Jan 26 06:57:50 2021
> Image Type: ARM Linux Script (uncompressed)
> Data Size: 324 Bytes = 0.32 KiB = 0.00 MiB
> Load Address: 00000000
> Entry Point: 00000000
> Contents:
> Image 0: 316 Bytes = 0.31 KiB = 0.00 MiB
> Because our setup also depends on the rtems-zynq-mkimg command and the rtems environment to be available we wanted to switch to the usage of the mkimage.py command which comes via RTEMS.
> BUT every script image we generate with this tool behaves different than the one we generated with mkimage.
> First of all is the output different, including a different resulting file size and a missing contents section.
> mkimage.py -A arm -T script -C none -n "fancy name" -d bootscripts/rtems rtems.img
> Created: Tue Jan 26 08:00:06 2021
> Image Type: none
> Data Size: 316
> Load Address: 0
> Entry Point: 0
> Adding the OS option with linux or u-boot does seem to change something, but the resulting script image is again not usable.
> I became aware of this because when a script image like this is uploaded to U-Boot and sourced, no error occurs but also nothing else happens.
> Usually it should print some information on what the script is doing and then well do its intended operations like it does when it is converted via the mkimage script.
> Has somebody else had the same issue and maybe even overcome it?
> Or does anybody have a clue where the problem may originate from?
> Thanks in advance for the answer and help.
> [1] https://wiki.trenz-electronic.de/display/PD/TE0715+TRM#TE0715TRM-KeyFeatures
> [2] https://wiki.trenz-electronic.de/display/PD/TE0706+TRM#TE0706TRM-KeyFeatures
> [3] https://www.denx.de/wiki/DULG/UBootScripts
> Best regards
> Andre Nahrwold
> Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR) German Aerospace Center Institute for Software Technolog | SRV-OSS BS | Lilienthalpl. 7 | 38108 Braunschweig | Geb. 112C Raum 001 M.Sc. Andre Nahrwold | Telephone +49 531 295-3834 | andre.nahrwold at dlr.de DLR.de
> users mailing list
> users at rtems.org
> users mailing list
> users at rtems.org
