MVME2500 (qoriq_e500) no longer boots with RTEMS6
Joel Sherrill
joel at rtems.org
Fri Feb 19 21:11:26 UTC 2021
On Fri, Feb 19, 2021 at 3:07 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> On 19/02/2021 19:52, junkes wrote:
> > On 2021-02-19 18:40, Gedare Bloom wrote:
> >> Advise how you built. We are starting to see some bitrot breakage in
> >> configuration. The cutover to waf will come soon, and I don't expect
> >> rtems6 release to support autoconf build of rtems itself. I suggest
> >> you change over to waf build of rtems kernel if you haven't yet.
> > I use a build system from Christian Maurer:
> > https://gitlab.com/c-mauderer/rtems-simulation-environment
> It's not really a build system but only a Makefile that collects the
> commands so that I can run some quick tests. Please also note that this
> is no official repo. So don't be surprised if it changes or breaks.
This is exactly why I haven't been prone to share my rtems-cron-helpers
which includes a build_bsp script which makes waf and autoconf look the
same from the command line. It also can run the tester. Saves me a lot of
keyboarding :)
--joel
> > define build_toolchain
> > rm -rf $(RSB)/rtems/build
> > cd $(RSB)/rtems && ../source-builder/sb-set-builder \
> > --prefix=$(PREFIX) \
> > --log=$(RSB)/b-rsb-toolchain-$(1).log \
> > $(RTEMS_VERSION)/rtems-$(1)
> > define build_bsp
> > cd $(SRC_RTEMS) && ./waf clean || true
> > cd $(SRC_RTEMS) && ./waf bsp_defaults --rtems-bsps=$(1)/$(2) >
> > config.ini
> > cd $(SRC_RTEMS) && sed -i \
> > -e "s|RTEMS_POSIX_API = False|RTEMS_POSIX_API = True|" \
> > -e "s|CLOCK_DRIVER_USE_FAST_IDLE =
> > True|CLOCK_DRIVER_USE_FAST_IDLE = False|" \
> > -e "s|BUILD_TESTS = False|BUILD_TESTS = True|" \
> > config.ini
> > cd $(SRC_RTEMS) && ./waf configure --prefix=$(PREFIX)
> > cd $(SRC_RTEMS) && ./waf install
> > endef
> > define build_libbsd
> > rm -rf $(SRC_LIBBSD)/build
> > cd $(SRC_LIBBSD) && ./waf configure \
> > --rtems-bsps=$(1)/$(2) \
> > --enable-warnings \
> > --optimization=2 \
> > --rtems-version=$(RTEMS_VERSION)
> > cd $(SRC_LIBBSD) && ./waf install
> > endef
> > I would like to switch to waf. But this is not available for the
> > kernel with RTEMS5 and unfortunately it does not work with RTEMS6.
> > Heinz > _______________________________________________
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210219/3340da0c/attachment-0001.html>
