Issue with configure on MacOS
Joel Sherrill
joel at rtems.org
Wed Jan 6 02:47:21 UTC 2021
On Tue, Jan 5, 2021, 8:36 PM <groups at chichak.ca> wrote:
> Any ideas or pointers?
> Did you forget to add something to c/src/libbsp? The autoconf builds
> system files are under the old tree while all the code is under bsps/. This
> makes it easier to remove the old build system when all is done.
> likely. In c/src/lib/libbsp/arm I created a new folder called stm32f767
> that contains configure.ac and Makefile.am with (my version of)
> appropriate modifications for my ‘767 board.
> I assumed that autoconf would pick up all of the stuff in c/src and
> somehow use bsps, but do I need to munge any config files or is the
> presence of the BSP folders in bsps and c/src/lib/libbsp all?
Is the bsp listed in the M4 file in libbsp/arm?
> Andrei
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210105/5b9117dc/attachment.html>
