RTEMS Fatal Error on IMX7D SABRE Board.
Christian Mauderer oss at c-mauderer.de
Wed Jan 6 13:17:18 UTC 2021
Hello,
On 06/01/2021 13:25, jameszxj wrote:
> Hi,
>  > Hello,
>  > On 06/01/2021 10:04, jameszxj wrote:
>  > > Hi,
>  > > I can't find "timer" node in your devicetree.
>  > > Function arm_generic_timer_get_config() in file bspstart.c will find
>  > > node "/timer"
>  > > and get "clock-frequency" value for system tick.
>  > note that at least the clock-frequency is added by U-Boot on the i.MX7
>  > during boot and is not in the typical device tree sources.
>  > On i.MX6UL/ULL there is still an ugly hack necessary:
> https://github.com/grisp/rtems/commit/02270d5ec82684007ae9973070a6f29428be1543
>  > It's on my TODO-list to avoid that patch, but I haven't done that yet.
> I add the timer_init in bsp, but the tick interrupt still seems pending.
> When I type something in shell, ticks will come.
Sounds like some low power mode. I would suggest to check the settings
in the CCM. Check whether the system enters low power mode on a WFI
instruction and disable that feature. Especially interesting would be
the CCM_CLPCR.MASK_CORE0_WFI and similar bits. If these seem to be
correct, I would check the CCGR* registers.
>  > > ------------------ Original ------------------
>  > > *From:* "JunBeom Kim (EmbedCoreTech)" <jbkim at e-coretech.kr>;
>  > > *Date:* Wed, Jan 6, 2021 04:46 PM
>  > > *To:* "'jameszxj'"<jameszxj at gmail.com>;"'users'"<users at rtems.org>;
>  > > *Subject:* RE: RTEMS Fatal Error on IMX7D SABRE Board.
>  > > Dear James,
>  > > As I know before, because this BSP is tested on Phytec’s
> PhyBOARD-i.MX7
>  > > board, I am considering to purchase this board, too.
>  > The last test on that board is some time back because I currently don't
>  > have access to it (working from home). So also I would hope it, I
>  > wouldn't guarantee that it runs out of the box.
> thanks.
>  > > Best Regards,
>  > > JunBeom
>  > > *From:*JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>
>  > > *Sent:* Wednesday, January 6, 2021 5:39 PM
>  > > *To:* 'jameszxj' <jameszxj at gmail.com>; 'users' <users at rtems.org>
>  > > Dear James,
>  > > I used two files(imx7d-sdb.dts and imx7d.dtsi) for making
> imx7d-sdb.dtb.
>  > > There is clock-frequency configuration in imx7d.dtsi.
>  > Again: Normally U-Boot should add that clock-frequency.
>  > > Best Regards,
>  > > JunBeom
>  > > *From:*users <users-bounces at rtems.org
> <mailto:users-bounces at rtems.org>>
>  > > *On Behalf Of *jameszxj
>  > > *Sent:* Wednesday, January 6, 2021 4:13 PM
>  > > *To:* users <users at rtems.org <mailto:users at rtems.org>>
>  > > *Subject:* Re:RTEMS Fatal Error on IMX7D SABRE Board.
>  > > Hi,
>  > > I use IMX7 bsp on my imx6ull board. I have encountered maybe the same
>  > > problem. Please check your device-tree, BSP needs "clock-frequency" at
>  > > node "timer".
>  > Do you use an i.MX6ULL with U-Boot or Barebox? They might have slightly
>  > different behavior regarding the timer.
> I use barebox.
OK. Barebox definitively doesn't initialize the timer. Odd thing is that
I don't remember that it switches on a power save mode. But maybe
something changed in a more recent version ...
Best regards
Christian
>  > > But I encountered another problems, theARMv7-AR Generic Timercan not
>  > > generate interrupt.
>  > > imx7d has the same core with imx6ull,if your board run RTEMS
>  > > successfully, please let me know, thanks.
>  > As you might have seen above, I'm using the BSP on i.MX6ULL based
>  > boards. The board uses Phytec Phycore i.MX6UL/ULL modules (different
>  > variants in different projects). One of the projects is an open source
>  > one and you can find all sources at:
>  >      https://github.com/grisp/grisp2-rtems-toolchain
>  > > *From:*"JunBeom Kim (EmbedCoreTech)" <jbkim at e-coretech.kr
>  > > <mailto:jbkim at e-coretech.kr>>;
>  > > *Date:*Wed, Jan 6, 2021 01:05 PM
>  > > *To:*"users"<users at rtems.org <mailto:users at rtems.org>>;
>  > > *Subject:*RTEMS Fatal Error on IMX7D SABRE Board.
>  > > Hello,
>  > > After I purchased i.MX7D SABRE board, I am trying to test RTEMS
> kernel using
>  > > lastest RTEMS kernel and source builder for RTEMS 6.0
>  > > As I knew before, RTEMS BSP for i.MX7D was not tested for i.MX7D SABRE
>  > > board.
>  > > When I tested this, my testing result is in below;
>  > > <REMARK> rtems.img is made by calling mkimage.
>  > > At this time, I am trying to debug RTEMS BSP using GDB with J-Link
> probe.
>  > > There is problem for executing start.S assembly code as source code
> level.
>  > Can you try to set a breakpoint on at least _Terminate and do a
>  > backtrace (bt in gdb)? I think the _ARM_Exception_default could be a
>  > useful one too.
>  > Best regards
>  > Christian
>  > > Please advise me.
>  > > U-Boot 2020.10 (Jan 05 2021 - 09:44:38 +0900)
>  > > CPU:Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz)
>  > > CPU:Commercial temperature grade (0C to 95C) at 38C
>  > > Reset cause: POR
>  > > Model: Freescale i.MX7 SabreSD Board
>  > > Board: i.MX7D SABRESD in non-secure mode
>  > > DRAM:1 GiB
>  > > PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
>  > > MMC:FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
>  > > Loading Environment from MMC... *** Warning - bad CRC, using default
>  > > environment
>  > > Video: 480x272x24
>  > > In:serial
>  > > Out:serial
>  > > Err:serial
>  > > Hit any key to stop autoboot:0
>  > > => fatload mmc 0 0x80800000 rtems.img
>  > > 36463 bytes read in 23 ms (1.5 MiB/s)
>  > > => fatload mmc 0 0x83000000 imx7d-sdb.dtb
>  > > 33369 bytes read in 22 ms (1.4 MiB/s)
>  > > => bootm 0x80800000 - 0x83000000
>  > > ## Booting kernel from Legacy Image at 80800000 ...
>  > > Image Name:RTEMS
>  > > Image Type:ARM Linux Kernel Image (gzip compressed)
>  > > Data Size:36399 Bytes = 35.5 KiB
>  > > Load Address: 80200000
>  > > Entry Point:80200000
>  > > Verifying Checksum ... OK
>  > > ## Flattened Device Tree blob at 83000000
>  > > Booting using the fdt blob at 0x83000000
>  > > Uncompressing Kernel Image
>  > > Using Device Tree in place at 83000000, end 8300b258
>  > > Starting kernel ...
>  > > *** FATAL ***
>  > > fatal source: 6 (RTEMS_FATAL_SOURCE_BSP)
>  > > fatal code: 3072 (0x00000c00)
>  > > RTEMS version: 6.0.0
>  > > RTEMS tools: 10.2.1 20201222 (RTEMS 6, RSB
>  > > d3dc0bc3861362978cdf65725e4ba2b64e283d32, Newlib 415fdd4)
>  > > Executing thread is NULL
>  > > Best Regards,
>  > > JunBeom Kim
>  > > _______________________________________________
>  > > users mailing list
>  > > http://lists.rtems.org/mailman/listinfo/users
>  > > <http://lists.rtems.org/mailman/listinfo/users>
>  > > users mailing list
>  > > users at rtems.org
