Delay until in Ada seems not to work
Mattia Bottaro
mattiabottaro9 at gmail.com
Wed Jan 27 10:54:02 UTC 2021
If you look at rtems_init.c file in that folder (<
https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2>),
you can see that there is no time of day. I thought it was ok since I'm
running an example.
Anyway, I've added time of day in rtems_init.c with these values:
https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39.
I've also set it with status = rtems_clock_set( &time ) , but the behaviour
does not change.
Il giorno mar 26 gen 2021 alle ore 23:44 Joel Sherrill <joel at rtems.org> ha
scritto:
> On Tue, Jan 26, 2021 at 4:37 PM Mattia Bottaro <mattiabottaro9 at gmail.com>
> wrote:
>> Hello,
>> I'm testing the delay_until example from ada-examples-4-10-2. You can
>> download it from <
>> https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2>.
>> It seems that the delay until has no effect. The program executes the
>> main loop ASAP and no suspension is performed. Given a period of
>> 16_666_667, 1000 iterations should complete in 16.67 seconds, but they
>> actually complete instantly.
>> Is anyone experiencing the same problem?
>> I'm using RTEMS 4.11.
> Is the time of day set? What is the time of day and what is the until time?
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210127/ed488c93/attachment.html>
