Delay until in Ada seems not to work
Wed Jan 27 13:25:37 UTC 2021
On 27/01/2021 11:54, Mattia Bottaro wrote:
> If you look at rtems_init.c file in that folder
> (<https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2
> <https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2>>),
> you can see that there is no time of day. I thought it was ok since
> I'm running an example.
> Anyway, I've added time of day in rtems_init.c with these values:
> https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39
> <https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39>.
> I've also set it with status = rtems_clock_set( &time) , but the
> behaviour does not change.
On which BSP and hardware did you try this out?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
