Delay until in Ada seems not to work
Mattia Bottaro
mattiabottaro9 at gmail.com
Wed Jan 27 14:27:00 UTC 2021
I've not specified it because I'm in a "non-conventional" situation: I'm
running RTEMS over XtratuM: <https://fentiss.com/products/hypervisor/>.
I'm using a BSP developed by FentISS. The hardware is the zynq7000.
Il giorno mer 27 gen 2021 alle ore 14:25 Sebastian Huber <
sebastian.huber at embedded-brains.de> ha scritto:
> On 27/01/2021 11:54, Mattia Bottaro wrote:
> > If you look at rtems_init.c file in that folder
> https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2
> > <https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2>>),
> > you can see that there is no time of day. I thought it was ok since
> > I'm running an example.
> > Anyway, I've added time of day in rtems_init.c with these values:
> https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39
> https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39>.
> > I've also set it with status = rtems_clock_set( &time) , but the
> > behaviour does not change.
> On which BSP and hardware did you try this out?
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/users/attachments/20210127/f86c22f7/attachment.html>
