Using LwIP on the STM32H7
Robin Müller robin.mueller.m at gmail.com
Fri Jan 29 11:52:01 UTC 2021
Hi,
I am actually configuring the MPU with the following function, which was
taken over from the STM32 example project:
/*Configure the MPU attributes */
void MPU_Config(void)
    MPU_Region_InitTypeDef MPU_InitStruct;
    /* Disable the MPU */
    HAL_MPU_Disable();
    /* Configure the MPU attributes as Device not cacheable
     for ETH DMA descriptors */
    MPU_InitStruct.Enable = MPU_REGION_ENABLE;
    MPU_InitStruct.BaseAddress = 0x30040000;
    MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
    MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
    MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
    MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
    MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
    MPU_InitStruct.Number = MPU_REGION_NUMBER0;
    MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
    MPU_InitStruct.SubRegionDisable = 0x00;
    MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
    HAL_MPU_ConfigRegion(&MPU_InitStruct);
    /* Configure the MPU attributes as Cacheable write through
     for LwIP RAM heap which contains the Tx buffers */
    MPU_InitStruct.BaseAddress = 0x30044000;
    MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
    MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
    MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
    MPU_InitStruct.Number = MPU_REGION_NUMBER1;
    /* Enable the MPU */
    HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
If I read the function correctly, it configures the descriptor areas as
non-cacheable and the LwIP heap region
as non bufferable. I call this in hardware_init, which is the first
function called in my Init funnction
void hardware_init() {
    BSP_LED_Init(LED1);
    BSP_LED_Init(LED2);
    BSP_LED_Init(LED3);
    MPU_Config();
    /* Initialize the LwIP stack */
    lwip_init();
    /* Configure the Network interface */
    Netif_Config();
I checked everything again and basically the setup appears to be identical
to the example now.. I'm confused that it's not working.
I also supplied the following interrupt function in my C code:
  * @brief  This function handles Ethernet interrupt request.
  * @param  None
  * @retval None
void ETH_IRQHandler(void)
  HAL_ETH_IRQHandler(&EthHandle);
But it appears not to be called..
Kind Regards
Robin
On Fri, 29 Jan 2021 at 12:03, Sebastian Huber <
> On 29/01/2021 12:01, Robin Müller wrote:
> > The HAL_ETH_Transmit call just times out. If I set the timeout to 20
> > to HAL_MAX_DELAY, the function will just block indefinitely.
> > Does anyone have an idea why this might happen?
> I would check the memory settings in the MPU for this area. You probably
> need some sort of device memory (uncached).
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/users/attachments/20210129/faa1ffd5/attachment-0001.html>
