Using LwIP on the STM32H7
Fri Jan 29 13:17:50 UTC 2021
On Fri, Jan 29, 2021, 5:52 AM Robin Müller <robin.mueller.m at gmail.com>
wrote:
> Hi,
> I am actually configuring the MPU with the following function, which was
> taken over from the STM32 example project:
> /*Configure the MPU attributes */
> void MPU_Config(void)
>     MPU_Region_InitTypeDef MPU_InitStruct;
>     /* Disable the MPU */
>     HAL_MPU_Disable();
>     /* Configure the MPU attributes as Device not cacheable
>      for ETH DMA descriptors */
>     MPU_InitStruct.Enable = MPU_REGION_ENABLE;
>     MPU_InitStruct.BaseAddress = 0x30040000;
>     MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
>     MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
>     MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
>     MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
>     MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
>     MPU_InitStruct.Number = MPU_REGION_NUMBER0;
>     MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
>     MPU_InitStruct.SubRegionDisable = 0x00;
>     MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
>     HAL_MPU_ConfigRegion(&MPU_InitStruct);
>     /* Configure the MPU attributes as Cacheable write through
>      for LwIP RAM heap which contains the Tx buffers */
>     MPU_InitStruct.BaseAddress = 0x30044000;
>     MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
>     MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
>     MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
>     MPU_InitStruct.Number = MPU_REGION_NUMBER1;
>     /* Enable the MPU */
>     HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
> If I read the function correctly, it configures the descriptor areas as
> non-cacheable and the LwIP heap region
> as non bufferable. I call this in hardware_init, which is the first
> function called in my Init funnction
> void hardware_init() {
>     BSP_LED_Init(LED1);
>     BSP_LED_Init(LED2);
>     BSP_LED_Init(LED3);
>     MPU_Config();
>     /* Initialize the LwIP stack */
>     lwip_init();
>     /* Configure the Network interface */
>     Netif_Config();
> I checked everything again and basically the setup appears to be identical
> to the example now.. I'm confused that it's not working.
> I also supplied the following interrupt function in my C code:
>   * @brief  This function handles Ethernet interrupt request.
>   * @param  None
>   * @retval None
> void ETH_IRQHandler(void)
>   HAL_ETH_IRQHandler(&EthHandle);
> But it appears not to be called..
Is the irq being registered via the RTEMS interrupt APIs? If not and you
are getting an interrupt, I'd wonder why you aren't seeing a spurious
interrupt flagged.
It shouldn't be installed directly at the hardware level.
--joel
> Kind Regards
> Robin
> On Fri, 29 Jan 2021 at 12:03, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 29/01/2021 12:01, Robin Müller wrote:
>> > The HAL_ETH_Transmit call just times out. If I set the timeout to 20
>> > to HAL_MAX_DELAY, the function will just block indefinitely.
>> > Does anyone have an idea why this might happen?
>> I would check the memory settings in the MPU for this area. You probably
>> need some sort of device memory (uncached).
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax:   +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210129/b077e2e4/attachment-0001.html>
