Building a library for use with RTEMS via CMake
Mon Jul 19 13:26:09 UTC 2021
On Mon, Jul 19, 2021 at 8:17 AM <Andre.Nahrwold at dlr.de> wrote:
> Hello,
> I have built RTEMS 5 and its tools for the Xilinx Zynq Zedboard and installed the BSP and tools at a certain position on my machine.
> The tools are added to the PATH variable and RTEMS_BSPS is also available in the environment.
> Now we need to build a library for the use with RTEMS via CMake.
> For this we wanted to use the toolchain files.
> Does anybody know how to correctly setup such a toolchain file using the RTEMS compiler?
> We managed to get a toolchain file working which at least built the library.
> But when we wanted to link to this library during compilation of a RTEMS application we got a bunch of errors due to undefined references to standard library functions.
> Does anybody has a clue where this might origin from?
> Building a RTEMS application which does not use the own library works fine.
> Our toolchain file looks like this:
> # CMake toolchain file for ARM
> # The compiler is based on
> # The RTEMS_BSPS environment variable is expected to be set.
> set(ARCH arm)
> set(CMAKE_SYSTEM_NAME RTEMS5)
> set(CMAKE_CXX_FLAGS "" CACHE STRING "ARM RTEMS5 gcc additional compiler flags" FORCE)
It sounds like you didn't specify the compiler arguments. You are missing
the arguments which produce code for the Zynq CPU mode. This is
from the zynq qemu configuration
-march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
For rtems5, you also need other arguments like -B DIR -specs bsp_specs -qrtems
For rtems6, it is just -B DIR -qrtems
DIR will point to the installed BSP.
I don't see those in this configuration.
> set(RTEMS_TOOLS_PATH $ENV{RTEMS_BSPS}/../../tools/bin)
> set(CMAKE_C_COMPILER ${RTEMS_TOOLS_PATH}/arm-rtems5-gcc CACHE PATH "ARM RTEMS5 gcc" FORCE)
> set(CMAKE_CXX_COMPILER ${RTEMS_TOOLS_PATH}/arm-rtems5-gcc CACHE PATH "ARM RTEMS5 gcc" FORCE)
> set(CMAKE_CXX_COMPILER_AR ${RTEMS_TOOLS_PATH}/arm-rtems5-gcc-ar CACHE PATH "ARM RTEMS5 ar" FORCE)
> set(CMAKE_CXX_COMPILER_RANLIB ${RTEMS_TOOLS_PATH}/arm-rtems5-gcc-ranlib CACHE PATH "ARM RTEMS5 gcc ranlib" FORCE)
> set(CMAKE_RANLIB ${RTEMS_TOOLS_PATH}/arm-rtems5-ranlib CACHE PATH "ARM RTEMS5 ranlib" FORCE)
> set(CMAKE_READELF ${RTEMS_TOOLS_PATH}/arm-rtems5-readelf CACHE PATH "ARM RTEMS5 readelf" FORCE)
> set(CMAKE_STRIP ${RTEMS_TOOLS_PATH}/arm-rtems5-strip CACHE PATH "ARM RTEMS5 strip" FORCE)
> set(CMAKE_ADDR2LINE ${RTEMS_TOOLS_PATH}/arm-rtems5-addr2line CACHE PATH "ARM RTEMS5 addr2line" FORCE)
> set(CMAKE_LINKER ${RTEMS_TOOLS_PATH}/arm-rtems5-ld CACHE PATH "ARM RTEMS5 ld" FORCE)
> set(CMAKE_NM ${RTEMS_TOOLS_PATH}/arm-rtems5-nm CACHE PATH "ARM RTEMS5 nm" FORCE)
> set(CMAKE_OBJCOPY ${RTEMS_TOOLS_PATH}/arm-rtems5-objcopy CACHE PATH "ARM RTEMS5 objcopy" FORCE)
> set(CMAKE_OBJDUMP ${RTEMS_TOOLS_PATH}/arm-rtems5-objdump CACHE PATH "ARM RTEMS5 objdump" FORCE)
> set(CMAKE_TARGET_CONFIG_POSTFIX .rtems5_gcc_arm)
> Best regards
> Andre Nahrwold
> Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
> German Aerospace Center
> Institute for Software Technolog | SRV-OSS BS | Lilienthalpl. 7 | 38108 Braunschweig | Geb. 112C Raum 001
> M.Sc. Andre Nahrwold | Telephone +49 531 295-3834 | andre.nahrwold at dlr.de
> DLR.de
> users mailing list
> users at rtems.org
