porting IOCs from Linux to RTEMS
Siddons, David siddons at bnl.gov
Tue Jun 29 21:03:00 UTC 2021
Hi Tim,
  I'm sorry, I wasn't clear. I want this to be an RTEMS application, not a Linux application. We have been doing this with linux for several years, but only recently it seemed that RTEMS was more complete and robust than it used to be, so I'd like to explore that.
Pete.
________________________________
Sent: Tuesday, June 29, 2021 5:00 PM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>; rtems-users at rtems.org <users at rtems.org>; Siddons, David <siddons at bnl.gov>
Subject: Re: porting IOCs from Linux to RTEMS
Hi Pete,
I think Kiman Ha did that to make copies of softGlueZynq run at NSLS (because someone wanted to use the scaler in softGlueZynq).  As far as I know, Kiman's solution boots from the MicroSD card and autostarts an EPICS IOC.  You can run the EPICS IOC with or without softGlueZynq.
Tim Mooney (mooney at anl.gov) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Siddons, David via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, June 29, 2021 3:51 PM
Subject: porting IOCs from Linux to RTEMS
I need to build an EPICS IOC which can run without access to NFS mounts or TFTP mounts. The embedded system is a ZynQ-based system with ample persistent storage on a micro-SD card. It seems to me that libbsd provides a full range of file I/O facilities, and so a more Linux-like configuration should be possible. But I have no idea how to accomplish this! I suspect that I need to change ~/epics/base-7.0/modules/libcom/RTEMS/posix/rtems_init.c, since that seems to be where the NFS/TFTP stuff gets set up. Has anyone tried to do this?
Pete.
URL: <http://lists.rtems.org/pipermail/users/attachments/20210629/faa0099f/attachment.html>
