RTEMS 5 ARM gdb missing python support? Am I building it wrong?
Isaac Gutekunst isaac at isaac.cc
Thu Mar 4 19:41:18 UTC 2021
I recompiled the tools the exact same way, and the problem appears to be gone away. Sorry for the noise your inboxes!
Isaac
On Thu, Mar 4, 2021, at 10:54 AM, Isaac Gutekunst wrote:
> Hi Folks,
> It's been a while, but I'm back at using RTEMS again, which makes today a good day!
> What's not so good is when I compile the RTEMES 5 tools, using
>      ../source-builder/sb-set-builder 5/rtems-arm
> I get a gdb that seems to be missing the python components. I see exceptions like the following after almost every command:
>     Python Exception <type 'exceptions.NameError'> Installation error: gdb._execute_unwinders function is missing:
> Any ideas what could be causing this? Is this the correct way to build the tools in the first place? I'm targeting the TMS570 at the moment.
> Isaac
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210304/09430100/attachment.html>
