RTEMS 5 ARM gdb missing python support? Am I building it wrong?
Isaac Gutekunst isaac at isaac.cc
Thu Mar 4 18:54:40 UTC 2021
Hi Folks,
It's been a while, but I'm back at using RTEMS again, which makes today a good day!
What's not so good is when I compile the RTEMES 5 tools, using
     ../source-builder/sb-set-builder 5/rtems-arm
I get a gdb that seems to be missing the python components. I see exceptions like the following after almost every command:
    Python Exception <type 'exceptions.NameError'> Installation error: gdb._execute_unwinders function is missing:
Any ideas what could be causing this? Is this the correct way to build the tools in the first place? I'm targeting the TMS570 at the moment.
Isaac
