Problem by installing RTEMS 5.1 on Windows 10
Fri Mar 5 00:51:19 UTC 2021
On 5/3/21 7:11 am, Olga Syrbachova wrote:
> Hi! I have a problem installing RTEMS. I follow the tutorial step by step, but
> something goes wrong. I work on Windows 10.
> My steps after creating /c/opt/rtems
> $ wget
> https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/rtems-source-builder-5.1.tar.xz
> <https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/rtems-source-builder-5.1.tar.xz>
> $ tar Jxf rtems-source-builder-5.1.tar.xz
> $ mv rtems-source-builder-5.1 5.1
> $ source-builder/sb-check
> RTEMS Source Builder - Check, 5.not_released
> Environment is ok
> What does 5.not_released mean?
At a guess there is no VERSION file in the stop of the RSB source package which
would seem strange give this exists in releases. If there is it is a bug in the
RSB on Windows.
> By running
> $ ../source-builder/sb-set-builder --list-bsets
> I get
> RTEMS Source Builder - Set Builder, 5.1
> Traceback (most recent call last):
>   File "../source-builder/sb/cmd-set-builder.py", line 26, in <module>
>     setbuilder.run()
>   File "../source-builder/sb/setbuilder.py", line 722, in run
>     if not list_bset_cfg_files(opts, configs):
>   File "../source-builder/sb/setbuilder.py", line 670, in list_bset_cfg_files
>     print('Examining: %s' % (os.path.relpath(p)))
> LookupError: unknown encoding: cp65001
What shell environment are you using?
