Problem by installing RTEMS 5.1 on Windows 10
Olga Syrbachova
syrba4eva28 at gmail.com
Fri Mar 5 08:36:25 UTC 2021
Thank you very much for your reply. I'm using MSYS2 MinGW 64-bit.
Actually I also tried to install RTEMS 4.11.0 and 4.11.2 and I didn't
succeed.
After running:
$ ../source-builder/sb-set-builder --prefix=/opt/rtems/4.11
4.11/rtems-sparc --jobs=none
in ... at LAPTOP-NOT8H6PV MINGW64 /c/opt/rtems/4.11.0/rtems
I got this error:
package: expat-2.1.0-x86_64-w64-mingw32-1
Build Set: Time 0:04:39.603651
Traceback (most recent call last):
File "../source-builder/sb-set-builder", line 29, in <module>
setbuilder.run()
File "../source-builder/sb/setbuilder.py", line 502, in run
b.build(deps)
File "../source-builder/sb/setbuilder.py", line 354, in build
self.build_package(configs[s], b)
File "../source-builder/sb/setbuilder.py", line 191, in build_package
_build.make()
File "../source-builder/sb/build.py", line 471, in make
self.builddir()
File "../source-builder/sb/build.py", line 340, in builddir
self.rmdir(builddir)
File "../source-builder/sb/build.py", line 161, in rmdir
path.removeall(rmpath)
File "../source-builder/sb/path.py", line 150, in removeall
os.unlink(file)
PermissionError: [WinError 5] Zugriff verweigert: 'C:\\opt\\rtems\\4.11.0\\
rtems\\build\\e2xwm1\\expat-2.1.0\\xmlwf\\xmlwf.exe'
On Fri, 5 Mar 2021 at 01:51, Chris Johns <chrisj at rtems.org> wrote:
> On 5/3/21 7:11 am, Olga Syrbachova wrote:
> > Hi! I have a problem installing RTEMS. I follow the tutorial step by
> step, but
> > something goes wrong. I work on Windows 10.
> > My steps after creating /c/opt/rtems
> > $ wget
> https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/rtems-source-builder-5.1.tar.xz
> > $ tar Jxf rtems-source-builder-5.1.tar.xz
> > $ mv rtems-source-builder-5.1 5.1
> > $ source-builder/sb-check
> > RTEMS Source Builder - Check, 5.not_released
> > Environment is ok
> > What does 5.not_released mean?
> At a guess there is no VERSION file in the stop of the RSB source package
> which
> would seem strange give this exists in releases. If there is it is a bug
> in the
> RSB on Windows.
> > By running
> > $ ../source-builder/sb-set-builder --list-bsets
> > I get
> > RTEMS Source Builder - Set Builder, 5.1
> > File "../source-builder/sb/cmd-set-builder.py", line 26, in <module>
> > setbuilder.run()
> > File "../source-builder/sb/setbuilder.py", line 722, in run
> > if not list_bset_cfg_files(opts, configs):
> > File "../source-builder/sb/setbuilder.py", line 670, in
> list_bset_cfg_files
> > print('Examining: %s' % (os.path.relpath(p)))
> > LookupError: unknown encoding: cp65001
> What shell environment are you using?
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20210305/70488894/attachment-0001.html>
