Offline download of sources fails
Chris Johns
chrisj at rtems.org
Wed Mar 10 18:55:24 UTC 2021
On 10/3/21 11:57 pm, Joel Sherrill wrote:
> On Wed, Mar 10, 2021, 6:42 AM Ida Delphine <idadelm at gmail.com
> <mailto:idadelm at gmail.com>> wrote:
> Hello,
> On trying to download my sources using this command stated in the documentation:
> ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
> Unfortunately, I get some errors and the build fails:
> RTEMS Source Builder - Set Builder, 6 (47d540e7f9fe)
> error: exe: not found: (__bison) /usr/bin/bison
> error: exe: not found: (__flex) /usr/bin/flex
> error: host build environment is not set up correctly
> Build FAILED
> Please what's the way out? I've been trying to resolve this for hours.
> You are missing some programs on your development host.
> There is sb-check which will do a more thorough review of what you should have
> installed.
> I do not see your host listed but the Users Manual has a section for most host
> operating systems with detailed instructions for installing the dependencies.
> You need to use their package manager to install at least bison and flex. You
> are likely also missing some development libraries needed.
> Check the users guide.
Also have a look at the command sb-get-sources. It will fetch the source and
patches for all hosts and architectures.
